Input and output in PASM
Alexander (Sandy) Hapgood
I've been trying to learn assembly and was trying to figure out how to set the output of a pin based on the input of another pin. The output part came fairly easily but it took a while to figure out the input part. The following is the code I finally put together.
This code and setup is guaranteed to work at my house on my PPDB.
Operate an LED based on switch position
Demonstrates input and output in assembly
392
+3.3─────┳─────┐
│ ┫SW1
100k │ │
pin 2────┘ 
470
pin 3────────┐
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
var
pub Main
'Launch assembly code into cog 1
coginit(1, @switch, 0)
dat
org 0
switch mov mask1, #1
shl mask1, #2
andn outa, mask1 'make pin 2 an input
mov mask2, #1
shl mask2, #3
or dira, mask2 'make pin 3 an output
or outa, mask2
:start test mask1, ina wc 'set carry flag if bit set
if_c andn outa, mask2 'button up - LED off
if_nc or outa, mask2 'button down - LED on
jmp #:start
mask1 res 1
mask2 res 1
Check out the muxc and muxnc instructions. They can be used to set/clear bits of outa based the state of the carry flag with one instruction instead of two conditional instructions.
