Code Posting — Parallax Forums
Code Posting
edited 2012-10-08 15:41 in General Discussion
  Operate LED based on switch position
  Demonstrates input and output in assembly
          392
  +3.3─────┳─────┐
              │    ┫SW1
         100k │     │
  pin 2────┘     
               470
  pin 3────────┐
con
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
var
pub Main
  'Launch assembly code into cog 1
  coginit(1, @switch, 0)
dat
          org 0
switch    mov     mask1, #1
          shl     mask1, #2
          andn    outa, mask1    'make pin 2 an input
          mov     mask2, #1
          shl     mask2, #3
          or      dira, mask2    'make pin 3 an output
          or      outa, mask2
:start    test    mask1, ina  wc 'set carry flag if bit set
    if_c  andn    outa, mask2    'button up - LED off
    if_nc or      outa, mask2    'button down - LED on
          jmp     #:start
mask1      res 1
mask2      res 1
  • edited 2012-09-28 15:19
    The 392 ohm resistor is just what I had. I couldn't find any 160 ohm ones which is what I usually use to drive a switch circuit.
    This setup and code is guaranteed to work at my house on my propeller professional development board.
              392
      +3.3─────┳─────┐
                  │    ┫SW1
             100k │     │
      pin 2────┘     
                   470
      pin 3────────┐
    con
    var
    pub Main
    dat
              org 0
              shl     mask1, #2
              mov     mask2, #1
              shl     mask2, #3
              or      outa, mask2
              jmp     #:start
    mask1      res 1
    mask2      res 1
    edited 2012-10-06 15:01
    (Xandy) !
    Post Coding
    beeeeeep beep-beep
  • edited 2012-10-08 15:41
    [code]
    some code here
    [/code]
