Light Automator: does the BS2 have a built it timer or should i build one?
Hello people
im working in this system that will let me control 2 HID lights with the possibility of using it with a timer mode..
i kinda read that the BS2 module does not have a timer you can access.. is this correct?
i was thinkning then building a timer out of a IC406 chip so i could program it for different intervals (12hrs on 12 off, 18ON 6 OFF) and then activate it or bypass it from the stamp.... would this be a good way of tackling the problem?
would you recommend a better solution?
thanks in advance!
thanks in advance!
Because that chip uses an RC oscillator, the timing will not be very accurate and will drift. If you need accurate diurnal timing, a much better choice would be an RTC chip like the DS1302.
Thanks for the reply Phil, this chip sounds real interesting!!! but i think it might be too much?
i did read that the internal oscilator might drift over time, but what if i used an external with a Quartz crystal? would that be better or would that still drift too much?
thanks so much for the help!
