Max voltage on an input pin — Parallax Forums
groggorygroggory Posts: 205
edited 2012-09-27 16:24 in Propeller 1
If I have the propeller running at VDD=3V, and I have a signal being triggered by a lipo based source that in my case will range from 3.0V - 4.2V will that potentially high voltage damage the propeller? ...or should I do voltage translation?
    edited 2012-09-27 11:37
    A 2.2K series resistor should provide adequate protection to the pin.
  • SRLMSRLM Posts: 5,045
    edited 2012-09-27 11:44
    From the datasheet you have, on page 26, "Logic High" as Vdd, and you have "Voltage on all other pins with respect to Vss" as -0.3v to (Vdd + 0.3V).
    So, 3.6 volts in answer to your question.
    Logic high is defined as anything above 0.6Vdd, so anything above 2 volts. You could use a voltage divider to get the input you need.
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.2.pdf
    edited 2012-09-27 11:46
    From a theoretical point of view, if there is no current (IO pin is set to input [high impedance]) then won't the voltage on the IO pin be whatever the battery voltage is, ie up to 4.2 volts? Which is outside the absolute maximum ratings, and hence should be avoided?
  • groggorygroggory Posts: 205
    edited 2012-09-27 11:48
    Here's the circuit I'm picturing. I left out lots of stuff...I just added the bits that I think are pertinent to the conversation.
    What do you think?
    edited 2012-09-27 11:57
    Why not power the MAX17043 from the same source as the Propeller (which, BTW, should probably be 3.3v and not 3v)?
    But in any case, it doesn't matter. I2C defines only the logic low. Logic high is from the pullup resistor, so in your circuit the high voltage on the I2C lines is 3v. Which is fine: the MAX17043 datasheet has logic high as 1.4v+. So, you don't need the I2C series resistors.
    edited 2012-09-27 12:23
    The max17043 is acting as an always on supervisory circuit. Its connected to other things not pictured.
    That's why it's not connected to the prop's power, which is switched on and off.
    So you're saying my circuit is good, plus I can omit the series resistor, correct?
    edited 2012-09-27 13:34
    groggory wrote: »
    Ah. I assume by "connected to other things" you mean the !ALRT pin is connected to something? There isn't really much else to connect elsewhere...
    Anyway, yes, your circuit without the series resistors should work fine.
    edited 2012-09-27 13:39
    The operant spec is the current flowing into the protection diodes, spec'd at 500uA max. With a 4.2V input and a 3V supply, a forward-biased protection diode will have about 3.6V on its anode. With a 2.2K resistor in series with the 4.2V, the current into the protection diode will be (4.2 - 3.6) / 2200 = 272uA.
    Invoking the protection diodes is probably not the greatest way to go about it, but it's simple, ubiquitous, and effective.
    edited 2012-09-27 13:48
    It seems SRLM and PhiPi are at odds for an answer here.
    SRLM says no series resistors required.
    PhiPi says 2.2k series resistors required.
    My thoughts...
    If the max17043 is an I2C slave, then I assume that it will never drive either line high. It's SCL line will be high-z, it's SDA line will pulse ground or sit at high-z.
    The prop will be I2C master. It's SCL line will drive the line HIGH and LOW, aka +3 and 0V. It's SDA line will go to ground or be high-z.
    So really, the only question is whether the 3V pullup is considered HIGH by the max17043 when the max17043's VDD line is sitting at 4.2V (worst case, largest voltage difference). According to the MAX17043's datasheet on page 2, the V(IH) value (minimum logic high) is 1.4V. So that tells me that 3V is perfectly acceptable as a voltage for HIGH.
    Which makes me think that SRLM's response of, "no series resistors required" is correct.
    What do you guys think?
    Also, thank you so much for helping me with this! I really appreciate it!
    edited 2012-09-27 14:31
    We are not at odds over the circuit you posted. We're at odds over the original question, which had 4.2V directly to a Propeller I/O pin. It's a bit of a theoretical discussion now, since the information you posted changes the original parameters.
    Regarding the I2C interface: technically, according to the I2C specs, you need to pullup both the SDA and SCL lines, and only drive them low (never high). And yes, the 3V pullup is considered high by the MAX17043 (it's more than 1.4V).
    I'm glad you posted. It made me realize that you probably don't need I2C level shifters for 3.3V and 5V devices sharing the same bus. As long as 3.3V is considered high by all the devices then you could connect them all to a bus pulled up to 3.3v. It's a very convenient feature.
    @Phil
    Ok, so assuming it's ok (even if it's not Kosher), then why not just use a ridiculously large value, say 10Mohm? Then you could practically guarantee less that 500uA under any positive voltage input.
    edited 2012-09-27 14:42
    Good clarification. I did change the parameters of the question.
    To interface i2c on these two chips over these voltage parameters both lines should be pulled up to the propeller's VCC.
    I2c should never drive the high, however, I believe some of the i2c objects on the obex do... Even though that is outside the i2c spec
    A huge series resistor would increase rise times I believe... Which could lead to incorrect data being read off the i2c line... I may be wrong here. Also, if the input impedence of the prop were say 10M, and you used say, a 10M resistor, then sue to the voltage divider the prop would see 1/2 of your input voltage, which may no longer be correctly interpreted as high. Just throwing out an idea here
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-09-27 14:43
    Hi SLRM;
    SRLM wrote: »
    The simple answer is SPEED.
    With high valued series resisters even the small capacitance on the pins may cause unacceptably long charging times. Unless you can tolerate really slow interface rates.
    Duane
    edited 2012-09-27 14:44
    SRLM wrote:
    ... why not just use a ridiculously large value, say 10Mohm?
    Because that much resistance, combined with the pin capacitance would result in very slow rise and fall times at the pin.
  • average joeaverage joe Posts: 795
    edited 2012-09-27 15:56
    I believe we will be fine without the series resistor. I'm wondering if there is any advice for running the propeller on 3v as opposed to 3v3? Is there any advice or thoughts about this?
    Another question is about PLL accuracy over a wide temperature range, running @3v? (Say 45-120 F)
    Any thoughts or advice would be greatly appreciated!
  • jmgjmg Posts: 15,200
    groggory wrote: »
    Just to add to your confusion, I'll add another consideration :
    If this battery pack plugs in, you might consider series resistors as ESD / Misalign protection.
    You need to watch the logic low with the pullup/series, and leave some noise margin.
    2.2k might be a little large for that, 470R-1k more typical for a 10k pullup.
