Liquid Nitrogen + 1500 Ping Pong Balls
= Jolly Good Fun! Those wacky Brits... Don't try this at home, Kiddies.
http://news.yahoo.com/liquid-nitrogen-ping-pong-balls-crazy-science-fun-110426479.html
Or, cut to the chase: http://www.youtube.com/watch?v=dfiR1Rde7dI&feature=player_embedded#t=208s
Gremlins.
Didn't think about that at first, but it is a good question. My guess is that the recoil did occur, but the trash is in contact with the floor, so that wouldn't be visible. The floor looks like it is wooden, so it flexed downwards and then sprung back upwards. The trashcan has less momentum than before as the ping pong balls are gone, so the kick it gets from the floor causes it to spring into the air.
If the trashcan was sideways the recoil would only move it backwards. It's the floor contact that is key.
Nice knowing y'all.
My guess is that the flexible bottom bowed out, pushing against the floor and propelling the trashcan up.
But if that were the case than a cannon would recoil forward, not backwards like they do.
http://www.youtube.com/watch?v=aMTSaeo85TE
C.W.
Good thing you're working on that Westminster Flame Ball clock!!!
Phil - Newton's third law of motion.
Back in the day there was this place called Cryodyne and they used to give us for free liquid nitrogen! They would fill a 7-Eleven styrofoam cooler 1/3 of the way and poke some holes in top. What a fun ride home that was.
You're an absolute fiend for poking that hornet's nest, and I thank you sir!
I think it's the floor flexing. You can even see a few of the spilled balls jump off the floor at the same time as the trash can. (actually I think I can see the floor flex a bit in the slow motion replay too) As for the lack of delay, I'd expect the floor to be very stiff. It could easily compress and re-bound in 50-100 mili-seconds. That would look "instant" to human eyes.
Lawson
http://en.wikipedia.org/wiki/Newton%27s_cradle
...look at some of the other ping pong balls around the trashcan between frames 1 and 2... they go up as well at the same moment the trashcan does, indicating some reaction of the floor.
The explosion drives the trashcan into the floor by equal and opposite reactions from the explosion. The floor does flex as a response to the trashcan. The recoil of the floor causes the trashcan and some of the immediate surrounding ping pong balls to go up in synchronization as well.
As far as Newton's cradle, if one ball is raised and allowed to drop on a stationary ball, then on the opposite side only one ball will bounce out. Ok, we all see that, but if the stationary ball, happens to be a wall, then the ball that is dropped will 'bounce' against the wall (at twice the frequency).... rotate this 90 deg where the wall becomes the floor and apply the trashcan as if it were a ball. As far as the floor is concerned, there was no explosion, and the trashcan was dropped from some imaginary height.
As far as delay in time... based on the video assuming about 30 frames per second, there is at least one frame of delay from when the explosion occurs and the trashcan lifts off of the ground.
I think the bin was sitting on a conveyor?
AAAAAAAAAARRRRRRRGGGGGGGGGHHHHHHH
Nnnnnnnooooooo!!!!!!!!! Make it stop>>>>make it stop!!!!!!!!!!!
I would have to put my guess on the impact of all the ping pong balls being propelled upward and outward faster than they can exit the barrel. That force is translated into an upward force on the barrel wall by the ping pong balls in contact with it. The balls have all this upward and outward (maybe someone could figure the vector model of this motion) momentum after the explosion and it has to go somewhere. As to the surrounding balls on the floor jumping, my guess is that would be caused by the shockwave radiating outward through the floor. Similar to banging a surface with a hammer and seeing the nails laying on it jump even though the flex is minimal.
There's only one way to settle this. We need to conduct two additional experiments to prove or disprove our hypothesis.
First we confirm that floor contact in the direction of motion is necessary for the reverse kickback. To do this we conduct the experiment with either the can on its side or suspended off the floor.
Second, we need to figure out if it is the piston effect or a variation on Newton's cradle. We'll use a trash can with a rigid bottom that is flush with the floor to eliminate the piston effect.
I nominate Erco to conduct these experiments as his experience with flaming Boe-bots indicates he likes danger.
C.W.
http://www.youtube.com/watch?v=7C6LjfE5FTA
Google it.
The difference with the explosion and the can sitting on the floor is that part of the can (i.e. the center of the flexible bottom) accelerates downward, pushing off against the floor. So it's more like a standing high-jump than an elastic rebound.
