Scratching my head with this FSRW code... need some help — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-09-25 19:33 in Propeller 1
I am trying to write a block of data from dat to a uSD card. I can't seem to make this work. What am I doing wrong?
con
  _clkmode = xtal1 + pll16x
  _clkfreq = 80_000_000
  MS_001   = 80_000_000 / 1_000
  SD_DO  = 0                                            ' SD card pins
  SD_CLK = 1
  SD_DI  = 2
  SD_CS  = 3
obj
  term   : "fullduplexserialplus"                       ' for terminal output
  sd     : "fsrw"                                       ' SD card routines
var
pub main  | b, i, l, m, num_bytes
  term.start(31, 30, %0000, 115_200)                                            ' start terminal (use PST)
  pause(500)
  term.tx(0)        ' clear screen
  m := \sd.mount(SD_DO)                                                         ' start sd object and mount card
  if m == 0
    term.str(string("SD card mounted OK", 13))
  else
    term.str(string("SD card failed to mount / not present", 13))
  term.str(@version)                                                            ' display version on PST
  l := \sd.popen(string("test.txt"),"w")                                        ' open file for writing on sd card called test.txt
  if l == 0
    term.str(string("test.txt file opened", 13))
  else
    term.str(string("File failed to open", 13))
  i := 0        ' initialize index
  repeat i from 0 to 270                                                        ' cycle through data and write to sd card
    b := \sd.pwrite(data[i], 2)
    term.dec(i)        ' show index counter on PST
    term.tx(32)
  term.tx(13)
  term.dec(b)        ' show number of bytes written to card
  term.tx(13)
  pause(1000)
  l := \sd.pclose                                                               ' close sd card file
  if l == 0
    term.str(string("File closed", 13))
  else
    term.str(string("File failed to close", 13))
pub pause(ms) | t
  t := cnt
  repeat ms
    waitcnt(t += MS_001)
dat
version byte  "sniff_playground", 13, 0
data    byte  $0B, $0B, $00, $33, $33, $00, $10, $10, $00, $0B, $0B, $00, $33, $33, $00, $10, $10, $00, $0B, $0B, $00, $33, $33, $00, $10, $10, $00
Forgot to mention that this is what I see:
Edit: Added screen shot of PST
1024 x 341 - 63K
  • Don MDon M Posts: 1,654
    edited 2012-09-25 16:21
    Oops.. I see my repeat loop should only go to 269 (or 270 -1) but that didn't help....
    I should also mention I'm using Martins new DNA board and 2 GB sd card.
    edited 2012-09-25 16:59
    pwrite requires a pointer, so you should pass @data instead of data to it. However, that's not causing the pclose failure. Print out the return code that you get from pclose and that should help to narrow down the problem.
    edited 2012-09-25 17:14
    Okay I made it a bit further but the data stored on the SD card is not what I expected. I thought I would see the hex bytes stored. Evidently I must be using the wrong format...
    Here's my new code:
    con
      SD_CLK = 1
      SD_DI  = 2
      SD_CS  = 3
    obj
    var
      pause(500)
      if m < 0
        abort
      else
      if l < 0
      else
      repeat i from 0 to 270 - 1                                                    ' cycle through data and write to sd card
        b := \sd.pwrite(@data[i], 2)
        term.tx(32)
      term.tx(13)
      term.tx(13)
      pause(1000)
      if l < 0
      else
      l := \sd.unmount
      if l < 0
        term.str(string("Failed to unmount", 13))
      else
        term.str(string("Card unmounted", 13))
    pub pause(ms) | t
      t := cnt
      repeat ms
    dat
    PST screen shot:
    Notepad screen shot:
    962 x 321 - 17K
    1024 x 182 - 20K
    edited 2012-09-25 18:30
    So I'm still kind of lost here. I've gotten the card writing part working and can store the DAT file. I had to convert the dat from $0B, $00, etc... to "0B 00 ...". It now stores them as ascii characters but that isn't what I want.
    How do I store it as hex data? I know this may seem elementary to some but it's confusing to me sometimes....
    edited 2012-09-25 18:40
    If all you want is the data table to appear in the file I'd use sd.pwrite(@data{0}, 270).
    edited 2012-09-25 19:23
    Well that kind of works but it seems like I'm missing some data. Not sure why.
    Here's my code:
    con
      SD_CLK = 1
      SD_DI  = 2
      SD_CS  = 3
    obj
      sd     : "fsrw2_6A"                                       ' SD card routines
    var
      byte  buf[500]
      pause(500)
      if m < 0
        abort
      else
      if l < 0
      else
        term.str(string("test.txt file opened in write mode", 13))
      sd.pwrite(@data{0}, 269)
      pause(1000)
      if l < 0
      else
      pause(1000)
      l := \sd.popen(string("test.txt"),"r")                                        ' open file for writing on sd card called test.txt
      if l < 0
      else
        term.str(string("test.txt file opened in read mode", 13))
      l := \sd.pread(@buf[0], 269)
      if l > -1
        term.str(string("Done", 13))
      pause(1000)
      l := \sd.unmount
      if l < 0
      else
      pause(1000)
      num_bytes := 270
      repeat i from 0 to num_bytes - 1
        term.hex((buf[i]), 2)
        i++
    pub pause(ms) | t
      t := cnt
      repeat ms
    dat
    data1   byte  "0B0B003333001010000B0B003333001010000B0B00333300101000"
    And here's what it prints out:
    Any ideas?
    1024 x 337 - 31K
    edited 2012-09-25 19:30
    The data table is 270 bytes in size so you really should write/read 270 bytes, not 269 (pwrite/pread expect a length value). Also, in your print loop get rid of the i++. What's it supposed to do? The way it's now you only print the even members (buf[2n]).
    kuroneko wrote: »
    That did it! Thanks. You're a genius! Thats what was causing it to skip over data.
    Thanks again. Marking this solved.
