DropBox, SPIN files, and Android Phone Problem
How can I view my Dropbox saved SPIN files on my Android Cell Phone?
I save all of my Propeller Projects on Dropbox, therefore they are all available at each computer that I use.
BUT, I have not found a way to view SPIN files on my Android Cell phone. I would like the ability to show, or review a Method while away from my computer. The SPIN files are listed in my Cell Phone Dropbox APP directory, but I can not access them. I get ERROR: "Download an APP to read this File Type".
I know this is really a DropBox issue, but wondering if anyone solved or found a way around this problem. Google searches has not helped.
I think what is needed is a "generic plain text viewer" for Dropbox.
Has anyone had or solved this problem.
Eldon
Eldon
Otherwise set a .spin file association to a text editor on your android.
Ok, but it would be nice not to have a browser open just to look a file.
This is what I would like to do, but via what magic is it done?
Eldon
You would think!, or assume!
There also the export feature. Drop the file in a directory on the SD card then use whatever text editor to view the file. You need a text editor and a file manager application.
Thanks, the guys on the forum come through!!
It worked! It is easy, Touchqode is automatic, does not require a messy attended download, nor any file transfers, nor file system directory navigation. It is accessed as a part of my DropBox App.
I can now just touch a file name in the DropBox APP, and start viewing - that is the way an APP should behave - Easy.
Eldon
So, I am not sure what installing Touchqode did to my Android configuration, It now works with several editors from which to choose.
Thanks, I am thankful for all of the advice provided here.
Eldon
BTW: (I may uninstall Touchqode to see if all of the editor choices still exist !)
UPDATE:
Dang, I uninstalled Touchqode - now Dropbox does not allow other editors to access my SPIN files - What's with that!
The free version will not open dropbox files.
If you buy the full version you can sync more than one directory.
