Turning on LED using PropGCC — Parallax Forums
tj_saggutj_saggu Posts: 3
edited 2012-09-25 05:23 in Propeller 1
Just wondering how I can turn on an LED using the GCC in simpleIDE.
thanks
  • RsadeikaRsadeika Posts: 3,902
    edited 2012-09-23 03:42
    There are no built in functions for this, not sure why. You have to include <propeller.h> in your program. It would also help if you show us your code, meaning, what have you tried so far.
    Ray
    #include <propeller.h>
    void high(int WCpin)
        unsigned int bits = 1 << WCpin;
        DIRA |= bits;
        OUTA |= bits;
    void low(int WCpin)
        unsigned int mask = 1 << WCpin;
        DIRA |= mask;
        OUTA &= ~mask;
    I must of scared the OP with my terse answer, so here is how it is done.
    Ray
     * @file basicLED.c
     * This is the main basicLED program start point.
        DIRA |= bits;
        OUTA |= bits;
    void low(int WCpin)
        DIRA |= mask;
        OUTA &= ~mask;
     * Main program function.
    int main(void)
        high(0);
        sleep(1);
        low(0);
        high(1);
        sleep(1);
        low(1);
        return 0;
