Tracks needed
So I have scoured the Internet looking for tracks for a robot without breaking the bank. I need tracks that are sturdy and about 4 to 5 inches wide for my project. I have looked in to building my own but this seems very time consuming. Does anyone know of a good source for tracks that are not trying to fund their business with one sale?
http://wardyprojects.blogspot.com/
check out the second page of this prop blog and the last post on the first page. its all about using a cheap rc tank chasis
Each size rubber ones are from snow blowers with wheels ( Large set and Small set)
Plastic ones are conveyor belts. (still have to find the 3 other wheels)
If interested PM me
Yea, I actually have those same tracks but they are just too small. Looking for something about twice the width/length of those type. Thanks though.
I've listed some links to other (smaller) treads in post #12 of my index. Of the smaller treads, I think the Lynxmotion and Vex look the most promising.
I have a couple of set of the Vex treads. I think Amanda has some of the Lynxmotion tread.
It's a lot of work but it makes for a very inexpensive and durable track.
I can't imagine making your own from car tires.Those sidewalls have steel inside.
But I do have a couple of salvaged timing belts that I have turned inside out so that the bumps are on the outside where they might provide traction. This are not so wide - about 2 inches. But with the right suspension and drive pulley, they could support quite a bit of weight.
Over the years I have looked and looked, but found nothing that is really low budget.
http://www.rctankcombat.com/articles/track-systems/
AFAIK no tires use steel for the sidewalls, and although some use steel for the belts, even that is not as common as it used to be. A small cheap car or trailer tire is not all that difficult to cut but they may be a bit too stiff for use on a small low powered robot. Works well for a large snow blower.
Is that 6" wide? If so, Can they be cut down or not? After doing the research I am thinking the conveyor belt type may be my best bet. That said, does anyone know where I can get them?
And thanks to all for the help.
Edit: I found what I need on EBay. Unless anyone that reads this post has any conveyor or timing belts they want to sell or trade I will be purchasing on Monday. Thanks again for all the help.
I've a pair of Pololu 80 RPM motors that may work, but they're on another 'bot right now.
Amanda
http://forums.parallax.com/showthread.php?93072-Boe-Bot-Mattracks&highlight=matt+tracks
As Amanda alluded, tracks are incredibly inefficient powerwise. They take tons of power just to move the track, not even touching the ground. On the ground, they are mostly skidding sideways in a turn. God help you if a tiny rock gets wedged between your tread and roller.
IMO, you'd be MUCH happier with 4, 6 or 8 large powered wheels per side. One of these old Rebound vehicles makes a nice 4WD chassis: http://www.ebay.com/itm/Tyco-R-C-Rebound-4X4-Vehicle-Only-No-Remote-Or-Battery-Untested-Sold-As-Is-/370654679506?pt=Radio_Control_Parts_Accessories&hash=item564cbd91d2
I actually like this idea. I only have 2 motors but was thinking I could weld sprockets on the wheels and use a chain system. I already have my chasis which is much larger than the one on EBay. Also, I need to either go with solid wheels or wheels that hold air due to the weight.
Alternatively, if you want rubber, check out parts for custom choppers. Those wide belts used between engine and tranny looks like they would make for beautiful tracks.
Probably won't be suitable for your bot, just mentioning it here in case someone else needs that size.
http://www.ebay.com/itm/Robotic-Tank-Chassis-Bomb-Dispoal-Robot-Arduino-PICAXE-STAMP-/320989166781?pt=LH_DefaultDomain_0&hash=item4abc71fcbd
I'm the guy that did that hack. I can tell you that those tracks are very poor quality, so I'd steer well clear of this product, unless you are going to drive it slowly and over nothing more challenging than thin carpet.
