Datalogging directly to Excel
I am designing a project which requires datalogging (max,min and average values) at various intervals. I wish to display this on a LCD (this is not a problem) but I also want to display it realtime on an excel sheet on a PC.
I am using a P8x32a programming in spin.
Each time a sample is taken I wish to transfer the max,min and average value on a opened excel sheet. I wish to do this by RS-232 comms if possible.
Which is the best approach?? Is there any an objects available on obex for something like this.
Then just a small bit of VBA code is required to poll the Propeller and get the data.
There is also a free program that does this that Parallax supports (I can't remember the name right now, maybe someone else can chime in).
Bean
http://www.robotbasic.org/2.html
Example For the Propeller chip
http://www.robotbasic.org/resources/RobotBASIC_To_PropellerChip_Comms.pdf
Option 2:
AN018: Communication with a PC Application
http://www.parallaxsemiconductor.com/an018
Perhaps you are thinking about the PLX-DAQ:
http://www.parallax.com/tabid/393/Default.aspx
Thanks, Yes that is the program I was thinking of...
Bean
re:Perhaps you are thinking about the PLX-DAQ:
Great thanks! I don't remember seeing that before. I downloaded it to have a look and it's nifty.
