How to mix or blend stereo channels into a monoaural amp
I bought some TDA5072A TDA7052A amplifier ICs and am pleased with the sound and the fact that so few external components are needed.
What is the best way to combine stereo channels like the VEHO 360 and similar devices do?
Is there a simple circuit or IC to accomplish this?
Ron
Ron
Put a 10k 1/4W carbon film resistor in each channel, and then tie their open ends together for a "down & dirty" passive mixer. Route that combined signal to your amp.
Heck - even 1k should be sufficient.
Thanks! Didn't realize it could be that simple.
Thanks Phil! Yes I meant TDA7052A.
It can be as complicated as you want!
*8)
Elliot Sound Products explains both, the best layouts, and the pros and cons. There are two ways to configure a mixer input for an op amp and one way is definitely wrong.
http://sound.westhost.com/
http://sound.westhost.com/articles/audio-mixing.htm
Take a good look at Virtual Earth Mixers to eliminate cross talk.
