NEED Help With PINK NetBurner Kit, Giant n00b
Hello everyone,
I just acquired a Parallax Internet NetBurner Kit (#30013) in one of my classes and I am having a rediculous amount of trouble getting communication between PINK and my P8X32A QuickStart Propeller board.
I was able to set up my network following the web configuration instructions, but I am not making any progress as far as coding goes. I would like to have a SPIN program that can communicate with the network, and perform tasks once it recognizes a value for a specific variable. There is only one demo program out there in SPIN for this netburner kit, and it is far too advanced for me to wrap my head around.
I am wonding if anyone could help me out with just a simple demo program that I could at least build off? Like I said earlier, I would like to set the value of say Nb_var00 to 4, then once my propeller board recognizes that this has been done, it can perform some other task.
Thank you SO much for your time.
-Eric - Engineering Student
Can you post the code you are working from? This way we can have a frame of reference to work with.
Thank you,
Daniel
* Pink V2 object test *
* Coded by Peter Verkaik *
* Date: December 19, 2007 *
CON
'clock settings for spin stamp
_clkmode = xtal1+pll8x
_xinfreq = 10_000_000
debugPort = 2 '0=none, 1=propeller TX/RX, 2=spin stamp SOUT/SIN
'//Spin stamp pin assignments
stampSOUT = 16 'serial out (pin 1 of spin stamp)
stampSIN = 17 'serial in (pin 2 of spin stamp)
stampATN = 18 'digital in (pin 3 of spin stamp, when activated, do reboot)
'//Propeller system pin assignments
propSCL = 28 'external eeprom SCL
propSDA = 29 'external eeprom SDA
propTX = 30 'programming output
propRX = 31 'programming input
'Application pin assignments
pinkRX = 10
pinkTX = 11
OBJ
myPink: "PinkV2" '//Pink declaration
debug: "MultiCogSerialDebug" '//debug serial driver
VAR
byte buf[64] 'buffer size equals maximum Pink variable size, holds asciiz string
byte debugSemID 'lock to be used by debug
long atnStack[10] 'stack for monitoring ATN pin
PUB main | pinkstat
'get lock for debug
debugSemID := locknew
'start debug
case debugPort
1: debug.start(propRX,propTX,0,9600,debugSemID)
2: debug.start(stampSIN,stampSOUT,0,9600,debugSemID)
waitcnt(clkfreq + cnt) 'wait 1 second
'monitor ATN pin (optional)
if debugPort == 2
cognew(atnReset,@atnStack)
'initialize Pink
myPink.PinkV2("0",pinkTX,pinkRX) 'the id "0" is currently the only one available
'send welcome message
debug.cprintf(string("PinkV2 test program\r"),0,false)
'check for network connection
repeat
myPink.getStatus
if myPink.noResponse
debug.cprintf(string("No response from Pink\r"),0,false)
else
if myPink.isConnected
debug.cprintf(string("Pink network connection established\r"),0,false)
until myPink.isConnected
'test write and read variable
myPink.writeVar(myPink#Nb_var00,string("[Just some value]"))
myPink.readVar(myPink#Nb_var00,@buf)
debug.cprintf(string("After writing [Just some value] to Nb_var00, it reads %s\r"),@buf,false)
'//send email message
debug.cprintf(string("Sending email...\r"),0,false)
repeat
myPink.getStatus
until myPink.isReady
'//set TO address
myPink.writeVar(myPink#Nb_varET,string("someone@somewhere.com"))
'//set FROM address
myPink.writeVar(myPink#Nb_varEF,string("PINK@parallax.com"))
'//set SUBJECT
myPink.writeVar(myPink#Nb_varES,string("Test Message From PINK"))
'//set MESSAGE CONTENT
myPink.writeVar(myPink#Nb_varEC,string("Message Content Goes Here!"))
'//set SMTP server
myPink.writeVar(myPink#Nb_varEV,string("smtp.server.com"))
'//set smtp USERNAME (optional on some servers)
' myPink.writeVar(myPink#Nb_varEU,string("username"))
'//set smtp PASSWORD (optional on some servers)
' myPink.writeVar(myPink#Nb_varEP,string("password"))
'//set smtp AUTHENTICATION on/off (optional on some servers)
' myPink.writeVar(myPink#Nb_varEA,string("1"))
'//send email
myPink.sendEmail
'//check email busy
repeat 'wait for Pink to become ready to send email again
pinkstat := myPink.getStatus
debug.cprintf(string("Pink status %08.8b\r"),pinkstat,false)
until myPink.isSent OR myPink.isReady
'//check email status
if myPink.isSent
debug.cprintf(string("Email sent succesfully\r"),0,false)
else
if myPink.isSent
else
debug.cprintf(string("Email send failure\r"),0,false)
'//send udp message
'//set DESTINATION ip address
myPink.writeVar(myPink#Nb_varBI,string("192.168.1.7"))
myPink.writeVar(myPink#Nb_varBM,string("Please Send Me A Reply To Port 10000!"))
'//set udp port
myPink.writeVar(myPink#Nb_varBP,string("10000"))
'//send udp
myPink.sendUdp
debug.cprintf(string("UDP message sent\r"),0,false)
'//receive udp message
'//check udp receive status
repeat
myPink.getStatus
until myPink.isUdp
'//read SOURCE ip address
myPink.readVar(myPink#Nb_varSU,@buf)
debug.cprintf(string("UDP message received from %s\r"),@buf,false)
'//read received udp message
myPink.readVar(myPink#Nb_varBM,@buf)
debug.cprintf(string("Message: %s\r"),@buf,false)
debug.cprintf(string("Program finished\r"),0,false)
repeat 'loop endlessly
PUB atnReset
if INA[stampATN] == 1
reboot
