Trouble with a PING Ultra Sonic Distance sensor
Copper
Preface: I have no Idea what I'm doing.
Now that we got that out of the way...
I picked up one of parallax's PING sensors just to fool around with while my other projects stew a little, but immediatly ran into trouble (inter-cog communication failure is my guess).
First I wrote a simple bit of code to use the driver provided here
which worked, so I know my PING sensor is functional and properly connected
Then I decided to try and integrate the PING sensor into a silly little synth object I had been fussing with earlier. Originally it used two Potentiometers to control the frequency, now I'm trying to use the PING sensor (for absolutely no reason other than to go through the exercise).
Unfortunately I've broken the PING sensor method such that it only returns one value (00000000000000000000010110010000), and I cannot for the life of me figure out what's wrong. I would very much appreciate whatever theories you may have, so that I can avoid creating the same problem in the future.
as always, thank you very much for your time.
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
Ping_Pin = 15
OBJ
pst : "Parallax Serial Terminal"
VAR
long ping_stack[30]
long debug_stack[30]
DAT
time long 0
distance long 0
frequency long 0
x long 0
ping_cog byte 0
debug_cog byte 0
PUB Main
debug_cog:=cognew(debug, @debug_stack[0])
ping_cog:= cognew(ticks(Ping_Pin), @ping_stack[0])
repeat
x|=(distance)
frequency:=x
'Synth("A", 4, frequency) 'Synth({Counter"A" or Counter"B"},Pin, Freq)
PUB Synth(CTR_AB, Pin, Freq) | s, d, ctr, frq
Freq := Freq #> 0 <# 128_000_000 'limit frequency range
if Freq < 500_000 'if 0 to 499_999 Hz,
ctr := constant(100 << 26) 'set NCO mode ( desired mode 100 shifted 26bits left into ctr-mode register [30..26] )
s := 1 '..shift = 1
else 'if 500_000 to 128_000_000 Hz,
ctr := constant(010 << 26) '..set PLL mode
d := >|((Freq - 1) / 1_000_000) 'determine PLLDIV
s := 4 - d 'determine shift
ctr |= d << 23 'set PLLDIV
frq := frqfraction(Freq, CLKFREQ, s) 'Compute FRQA/FRQB value
ctr |= Pin 'set PINA to complete CTRA/CTRB value
if CTR_AB == "A"
CTRA := ctr 'set CTRA
FRQA := frq 'set FRQA
DIRA[Pin]~~ 'make pin output
if CTR_AB == "B"
CTRB := ctr 'set CTRB
FRQB := frq 'set FRQB
PUB frqfraction(a, b, shift) : f
if shift > 0 'if shift, pre-shift a or b left
a <<= shift 'to maintain significant bits while
if shift < 0 'insuring proper result
b <<= -shift
repeat 32 'perform long division of a/b
f <<= 1
if a => b
a -= b
f++
a <<= 1
PUB Ticks(Pin) | cnt1, cnt2
''Return Ping)))'s one-way ultrasonic travel time in microseconds
repeat
outa[Pin]~ ' clear I/O Pin
dira[Pin]~~ ' make Pin Output
outa[Pin]~~ ' set I/O Pin
outa[Pin]~ ' clear I/O Pin (> 2 microsecond pulse)
dira[Pin]~ ' make I/O Pin Input
waitpne(0, |< Pin, 0) ' wait For Pin To Go HIGH
cnt1 := cnt ' store Current Counter Value
waitpeq(0, |< Pin, 0) ' wait For Pin To Go LOW
cnt2 := cnt ' store New Counter Value
time := ((||(cnt1 - cnt2) / (clkfreq / 1_000_000)) >> 1) ' store Time in microseconds
distance := (time * 10_000) / 29_034 ' store distance in (millimeters)
PUB Debug
pst.Start(57600)
waitcnt(clkfreq+cnt)
repeat
pst.str(string(13))
pst.bin(distance, 32)
waitcnt(clkfreq/4+cnt)
