Wire Wrap Question
I am just curious to find out if anyone does wire wrapping anymore. Specifically, Anyone on the Savage Circuits Traveling Parts Box list. I have some tools, etc and would like to know if anyone would find it useful or not.
Same here. Very handy for quickly prototyping a small circuit board or making the small changes/additions to a board that did not turn out as well as expected.
I also use the wire-wrap wire to repair broken or missing tracks on circuit boards.
But I use this tool for about $7. What's the difference between the cheapo and the more expensive tool?
What's that link you posted? It takes me to a reply-to-thread page.
Actually I paid above $200.00 for my Gardner Denver wrap tool in 1984, cut strip and wrap gun. It finally died two years ago so I went on ebay looking for a replacement. Bit was still in great shape. Turned out cheaper to replace the gun than fix. Found a cooper tools w/ 20 foot cord (probably surplussed out of a telco or government contractor) for about $25.00 and snapped it right up. Not quite G/D but does the job. Now if I could just find my old CPM backup disk along with my copy of a program called wiremaster.
When I worked for English-Electric-LEO-Marconi Computers 48 years ago, for wiring mainframe backplanes they evaluated both Gardner-Denver wire-wrap and an alternative technique using little crimped on tags that were pressed onto the posts (I forget whose it was). They chose the alternative technique, for some reason.
I sometimes thing of using wire wrap but the sockets and tools get expensive. You can probably design a PCB and get a one off made time it takes and with less expense.
It was really cool because you didn't strip the wire, it wrapped tight enough that the pins would cut into the insulation.
Wrapping bus type connections was very easy because you could just daisy chain from on device to the next.
I was very bummed when the bit wore to the point of being unreliable and could not find a source for a new one.
C.W.
Yep, good tool mostly. "mostly" was why I spent the bucks on the automatic cut strip modified wrap bit and the GD gun to drive it. One of its first uses was a Z80 based buffer box prototype using the latest (at the time) 64k * 1 dynamic rams that had come out avoiding the 16k*1 that required multiple supply voltages.
I never did purchase a motorized unit for my personal use, but I used them at work during the 80's.
My manual gun works just fine, and I have bits to outlive me. (When it comes time for my kids to divide up the loot, they are going to say, "what the heck is this stuff?"
http://www.jonard.com/jonard-ecommerce/control/product/~category_id=HAND_WRAP_TOOLS_1/~pcategory=OK_WIRE_WRAP_TOOLS/~product_id=10021;jsessionid=CAF73FB31794EF7FE625F5FA46E6FD42.jvm1#
It was the WSU-30M. I wore out a couple of them.
