Need to power-up/down auxiliary +5v Supply via Prop pin — Parallax Forums
KhrushchevKhrushchev Posts: 7
edited 2012-09-18 15:18 in Propeller 1
I have a prop circuit (see below) that uses a dual channel Vishay ILD213T optocoupler to interface a prop output and input to an external device requiring and returning a 5v signal. I have a separate (but not isolated) 5v supply for this side of the interface. I need to (occasionally) power the +5 side on and off via a prop pin. The 5v logic and load will draw less than 15mA. Could someone recommend a solution? I'm not experienced enough with FETs and Transistors to know the best and most economical way to do this. A circuit diagram would be most educational. Below is the current circuit as breadboarded. Pins 3 and 9 on J1 are prop pins.
436 x 250 - 52K
    edited 2012-09-17 18:58
    A single NPN transistor like a 2N3904 with a 1K base resistor could switch the low side (gnd) on and off. Add a PNP (2N3906) with another 1K base resistor to that if you must switch the high side (+5V) on and off. An optoisolator with a high CTR could also work for either high or low side switching.
  • max72max72 Posts: 1,155
    edited 2012-09-17 22:16
    I had a similar problem, and Tracy Allen posted many useful suggestions and explanations here:
    http://forums.parallax.com/showthread.php?142124-Low-power-guidelines
    Massimo
  • AribaAriba Posts: 2,697
    edited 2012-09-18 08:13
    You can use the same circuit that you have between J1-3 and J2-3 to switch a 5V supply on and off. The 5V supply pin is then the output of the inverter gate. A 74LVC1G04 output can drive more then 32 mA at 5V according the datasheet.
    Andy
  • KhrushchevKhrushchev Posts: 7
    Thanks kwinn, Massimo, and Andy. All very interesting and educational. Andy, your solution was staring me right in the face and I missed it! I chose the LVC because I needed 5v logic with a little more than 8mA of output drive. Funny, when I went scrounging for parts for breadboarding, I found a few unused DM74LS04N's in my junkbox from the late `70s. They had sat there for over 30 years and never inverted one bit ... until now.
    Rob
