power supply ripple and NMOS — Parallax Forums
Martin HodgeMartin Hodge Posts: 1,246
edited 2012-09-18 15:12 in General Discussion
I'm experimenting with switching power supplies, and have been able to produce a circuit that can supply 5VDC @1A from ~28VDC. What I haven't been able to glean from Google searches so far, is if 20mV P-P ripple @ 30kHz on a 5VDC PS is considered acceptable. The target application is a vintage 5-1/4" floppy drive controller board (an Atari 1050) with lots of NMOS ICs and analog. The original PS used linear vregs (7805 & 7812) which generated lots of heat.
    edited 2012-09-17 14:55
    20 mV sounds really good to me. I can't see how it would cause a problem. I've worked with switching supplies having up to 100 mV P-P ripple without issue.
  • jmgjmg Posts: 15,200
    edited 2012-09-17 15:16
    because the original design used Linear, that will be what they tested with.
    You can always add additional filtering, if you think this is going to challenge the FDC.
    - either an LC filter stage, or a low drop out linear regulator, and set the SMPS just above drop out.
    or retro-fit low impedance Caps to the 5V boards, and use the wire impedance, perhaps with a clip-on ferrite,as part of a somewhat hidden filter.
  • Martin HodgeMartin Hodge Posts: 1,246
    Thanks for the input. I'll keep tinkering knowing that I'm not way off base.
