Electronics 101 question
mark6320
Im a pure software guy with a very basic electrical 101-type question: I have a dc plug power extension cable that Im going to use on my Arduino based BoeBot. I want to insert an on/off toggle switch to easily switch power on and off from the battery pack without having to unplug the battery connector. My question is: do I put the switch on the negative or positive wire? Does it matter? Why?
Thanks much,
Mark
Thanks much,
Mark
Welcome to the forums! Personally I'd put it on the positive side so everything stays grounded, which may come in handy later.
To be extra safe you'd switch both sides of the battery (then either battery terminal can be accidentally shorted to ground without issue). This latter arrangement is called an isolation switch and means you could then accidentally short the +ve batt terminal to the "ground" without issue since the entire battery is floating.
