Prototype to PCB - should I?
doggiedoc
Perhaps the correct question is from proof of concept to prototype board. Or I am getting ahead of myself?
In my Automatic Chicken Coop project I have "prototyped" it together with the PropBOE (#32900). I really don't want to leave my PropBOE out in the chicken coop from now on so I'm thinking, if not a PCB then at least transfer to a Propeller Proto Board. The AD inputs on the PropBOE are the only unique aspects compared to the much cheaper Proto Boards (at least for what I need). Then there is Chris Savage's Dual Relay Board Kit (#27114) I am using. There may be enough real estate on a proto board for 1/2 of one of those as well.
So I'm wondering will it fit? I do have blank 3x4 proto boards (#45304) too. Hmmm.
So thinking along that line - I need to fit CdS and resistor, 1/2 Relay kit (will figure those parts shortly), and an ADC chip (plus supporting components)?
I welcome your thoughts and criticisms.
Brief video of project is here in this post on Savage Circuits.
Thanks!
Paul
Thanks!
Paul
It does sound like a good/fun opportunity to go from your proof of concept hardware to something better tailored and less expensive than a PBOE.
Part (component) Cost ($)
Proto Board25
CdS Cell?
Omron Relay2.99
Asteroid detection for Thursday?
This situation was exactly the reasoning behind my Quickstart Universal Prototyping board. You could build your circuit on something like that, then just plug it into the ready-to-go Quickstart board. Overall it's a little more expensive that having a PCB made cost-wise, but creates an inexpensive way to build a kit that doesn't stick you with bunch of custom PCBs.
Not to be too salesy, there is also a Prototyping board from Parallax that could be used like this as well.
Jeff
Paul
Terrific! A BS1 Kit is only $60! http://www.parallax.com/Store/Microcontrollers/BASICStampProgrammingKits/tabid/136/CategoryID/11/List/0/SortField/0/Level/a/ProductID/295/Default.aspx
Something doesn't add up here, huh?
For me it started with copper clad boards, laser printers, drills and etching solution. Now you kids get to use layout software and upload your design and have boards a week later, there are few reasons to not do that. Cost being one, if you can buy it cheaper then it makes sense to buy it. Sometimes you can find breakout boards for all of your components and just wire them together.
Anyway I'm sure you already know all this my point is to say get your feet wet with custom PCB it may open up a bunch of new projects
cant beat 4 dollars..
I was tarred once, and feathered too!!!!!!!!
from his post it doesnt sound like hes layed out a lot of props. a protoboard also has the advantage of being easly fixed if mistakes are made. no waiting for another run and it can be purchased and built in a day i.e no waiting on some service to send a board from china.
if the op has layed out plenty of boards and either needs 10 of or can find a 1 of big enough for a reasonable price then pcb all the way just make sure to break out all those extra pins for later
OSH Park (Dorkbot)
BatchPCB (Sparkfun)
Seeed Studio - Fusion PCB Service
iTead Studio PCB Prototyping service (may actually be the same people as Seeed Studio)
I think OSH Park boards are made in USA, all the others come from China.
The prices are very reasonable, but I think the only one that will do a single board is BatchPCB and they have a $10 setup fee.
I'm very interested to know where to get a single board made for $4 and how big it could be.
That is kind of the point though, get a couple done and eventually you will get them for $4 each.
I guess it was a small board if the order totaled $4 total. I don't think Doc's board can be made that little.
Or did you use the medium run option and cut the boards out yourself?
You get 10 boards, and it takes some time, depending on the shipping options.
Nonetheless their offer is hard to beat..
Massimo
