Case statement question — Parallax Forums
Don MDon M Posts: 1,653
edited 2012-09-12 14:52 in Propeller 1
For variable d which is a long I cant get the second line to work:
d = $52 for example
d := serial.rx
case d
  $0B:  Do this....
  (d & %0_01000000) == $40:  Do that...
I know the first line $0B works fine but the second line doesn't even though the equation does = $40. Maybe I'm stating this wrong? If I use it in an IF statement like this it works:
d := serial.rx
case d
  $0B:  Do this...
if (d & %0_01000000)
  Do that...
    edited 2012-09-12 14:30
    That's not how the CASE statement works. It calculates the expression on the CASE statement line, then essentially compares that to each of the expressions on each of the selection lines. Essentially it compares d to (d & %0_01000000) == $40 which always has the value 0 or $FFFFFFFF since it's a Boolean expression. That's not what you want. I suggest using the IF statement instead.
    You could try
    CASE d
       $0B:   ' This
       $40..$7F:   ' That
    Depending on what you want to do when the 8th bit is set, you might need to use $40..$7F, $C0..$FF:
    It gets more complicated, still, especially since he's dealing with 9-bit values:
    CASE d
       $0B:   ' This
       $40..$7F, $c0..$ff, $140..$17f, $1c0..$1ff:   ' That
    I think I'd go with the if ... elseif syntax for this one.
    Addendum: I suppose this could work:
    CASE true
      d == $0b: 'This
      d & $40 <> 0: 'That
    -P.
