Print a Negative Integer bug in compact printf — Parallax Forums
Christof Eb.Christof Eb. Posts: 1,538
edited 2012-09-12 12:16 in Propeller 1
there seems to be a bug in compact printf.
#include <stdio.h>
#include <propeller.h>
#include <sys/thread.h>
#include <math.h>
int main (void)
int a=123, b=-456;
sleep(2);
printf("hello, world! %d %d\n", a, b);
return 0;
brings:
hello, world! 123 -456 without compact printf
hello, world! 123 4294966840 with compact printf
Best regards
Christof
  • jazzedjazzed Posts: 11,803
    edited 2012-09-12 09:43
    What printf are you using? There is a printf in the tiny lib, and there is simple printf specified with -Dprintf=__simple_printf
    BTW, libtiny.a compiled for LMM will not work with CMM. We've packaged the library versions that are automatically included by GCC based on the model used.
  • Christof Eb.Christof Eb. Posts: 1,538
    edited 2012-09-12 10:27
    I use SimpleIde (Great tool!) and just set the hook for compact printf or omit it.
    Christof
    edited 2012-09-12 11:10
    Christof
    I'm not able to reproduce the problem by either checking "Simple Printf" or "Tiny Lib" with version 0-8-5.
    Can you please after building the failing condition, right-click build status and select-all, then copy and paste here?
    --Steve
    BTW, I'll be on line only briefly the rest of today/tonight.
    edited 2012-09-12 11:57
    Hi, this is:
    Project Directory: C:/Users/Christof/Documents/SimpleIDE/SineBurst/
    propeller-elf-gcc.exe -o a.out -Os -mcmm -I . -Wall -m32bit-doubles -fno-exceptions -Dprintf=__simple_printf -save-temps Test_prt.c -lm
    Test_prt.c: In function 'main':
    Test_prt.c:18:5: warning: implicit declaration of function 'sleep' [-Wimplicit-function-declaration]
    propeller-elf-objdump -h a.out
    Done. Build Succeeded!
    propeller-load.exe -I C:/propgcc/propeller-load/ -b DEMOBOARD -p COM6 a.out -r
    Propeller Version 1 on COM6
    Loading a.out to hub memory
    10180 bytes sent
    Verifying RAM ...
    OK
    Oh, I have just seen, that if I don't select maths library, it is working and I get very much smaller code. That's funny.
  • ersmithersmith Posts: 6,280
    Thanks Christof, that was just the clue we need. The version of _simple_printf in the math library has floating point support and support for 64 bit integers, which is why it's bigger, and also why it isn't working -- the integer parsing code is using 64 bit integers and not checking for 32 bit negative numbers. It should be easy to fix.
    Thank you for the bug report!
    Eric
