Trouble shooting a simple spin servo driver — Parallax Forums
CopperCopper Posts: 48
edited 2012-09-14 18:52 in Propeller 1
So I've run into a little trouble with my servo driver, and I'm sort of at a loss as to how I should proceed.
First off, you should know, I'm writing this driver as a learning exercise. I'm very new to programming. So while it may seem like a wasted effort, I would really like to continue developing this bit of code. I have downloaded and mulled over a number of servo drivers from the object exchange, but find most of it goes over my head. So I'm hoping building this driver from the ground up will help to expose me to all that needs to be addressed in a servo driver, and at least one way of doing it, so that I can begin to explore other drivers with some understanding.
I believe I have narrowed the problem down to some inter-relationship between multiple cog management and my signal timing.
{{Basic Servo Stuff}}CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  #0, For4, For3, For2, For1, stop, Rev1, Rev2, Rev3, Rev4
VAR
  long stackspace[100]
  word cog
PUB Main
  Start_Servo(12, For2, 3000)
  waitcnt(clkfreq*3)
  Start_Servo(12, For4, 3000)
  waitcnt(clkfreq*3)
  Start_Servo(12, Rev2, 6000)
  waitcnt(clkfreq*6)
PUB Start_Servo(servoPin, speed, duration)
  cog:=cognew(Run_servo(servoPin, speed, duration), @stackspace[0]) + 1
PUB Stop_Servo
  if cog
    cogstop(cog~ - 1)
PUB Run_Servo(servoPin, speed, duration) | tInc, dInc, tc, tHa, t, run_time
  'configure counterA
  ctra := (100 << 26 | servoPin)         'Counter A to NCO & Apin to servoPin
  frqa := 1                                 'increment phsa by 1
  dira[servoPin]~~                          'set servoPin to output
  'configure pwm signal
  tInc := clkfreq/1_000_000                 'set tInc == 1 microsecond
  tC   := tInc * 20_000                     'determine pulse delay
  tHa  := tInc * Speeds[speed]              'determine pulse width
  t    := cnt                               'mark counter time
  'detirmine runtime
  dInc := clkfreq/1000                      'set dInc == 1millisecond   dInc == Duration Resolution
  run_time:=((duration*dInc)+t)             'set run_time
  'begin sending signal
  repeat until t=>run_time                  'start PWM signal
    phsa := -tHa                            'send pulse for tHa seconds
    t += tC                                 'calculate end of cycle
    waitcnt(t)                              'wait for next cycle
DAT
  Speeds long 1000, 1200, 1450, 1500, 1515, 1530, 1580, 1830, 2000
Above, Is a trimmed up version of my driver (no ramping or serial port communication [neither of which probably work yet anyhow; we'll leave that for next time]).
When I run the code, the servo drives for 3sec at the given rate, but then there is a min+ delay before it starts again, it does start at the given rate and runs for 3sec, but I can't get it to start a third time (by changing the given parameters) or reduce the delay.
Hopefully something is glaringly wrong and easily explained, but whatever I've done wrong it's not apparent to me.
As always,
Thanks for your help.
    edited 2012-09-09 17:23
    The waitcnts between your Start_Servo calls are malformed (waitcnt(clkfreq*3 + cnt)). Furthermore, if the delay between Start_Servo calls goes below the time your servo cog needs to finish you'll effectively use the same stack for multiple SPIN instances, NG (remember that cognew returns almost immediately). It would be better to reserve a private stack for each instance unless you can make sure that it's only used by one instance at a time.
  • CopperCopper Posts: 48
    edited 2012-09-14 08:44
    Finally had a chance of spend some time with my servo driver...
    and kuroneko was right about the waitcnt command. So I went about adding a method for Ramping the servo speed, and a debug method to report the actual "speed" of each pulse. But I've hit another roadblock.
    I think the problem is in my ramping method
    OBJ
      pst : "Parallax Serial Terminal"
    VAR
      long servo_space[14]
      long ramp_space[32]
      long debug_space[32]
      word servo_cog, ramp_cog, debug_cog
    PUB Main
      debug_cog:=cognew(DEBUG(12), @debug_space[0])
      waitcnt(clkfreq*3)
      waitcnt(clkfreq*4+cnt)
      Start_Servo(12, rev3, 6000)
      waitcnt(clkfreq*7+cnt)
      servo_cog:=cognew(Run_servo(servoPin, speed, duration), @servo_space[0]) + 1   'launch and remember servo_cog @servo_space
      ramp_cog:=cognew(Ramp_Servo(servoPin, speed), @ramp_space[0]) + 1              'launch and remember ramp_cog @ramp_space
    PUB Stop_Servo
      if servo_cog                                               'if servo_cog == not 0
        cogstop(servo_cog~ - 1)                                  'stop and postclear servo_cog
        cogstop(ramp_cog~ - 1)                                   'stop and postclear ramp_cog
    PUB Run_Servo(servoPin, speed, duration)| t, run_time
      'time management
      tInc := clkfreq/1_000_000                                  'set tInc == (cnt ticks per microsecond)
      dInc := clkfreq/1000                                       'set dInc == (cnt ticks per millisecond)
      tC   := tInc * 20_000                                      'set delay period to 20_000 microseconds
      'configure counterA
      'detirmine start and runtime
      repeat until t >< 0                                        'repeat until start[servoPin]== >< 0
        t := start[servoPin]                                     'set t== start[servoPin]
      run_time[servoPin]:=((duration*dInc)+t)                    'set run_time
      repeat until t=>run_time[servoPin]                         'start PWM signal
        phsa := -(tInc * Speeds[LS[servoPin]])                   'send pulse for tHa seconds
      'clear servo data
      LS[servoPin] := 0
      start[servoPin] := 0
    PUB Ramp_Servo(servoPin, speed) | t
      if speed > LS[servoPin]                                    'if... then ramp up
        t := start[servoPin] := cnt                              'mark and share start time
        repeat until LS[servoPin] >= speed                       'repeat until at speed
         LS[servoPin]++                                          'increment speed
         t += tC                                                 'calculate end time
         waitcnt(t)                                              'wait until then
      elseif speed < LS[servoPin]                                'if... then ramp down (currently unecessary)
        repeat until LS[servoPin] <= speed
         LS[servoPin]--                                          'decrement speed
         t += tC
         waitcnt(t)
    PUB DEBUG(servoPin) | i
      pst.start(57600)                                           'start pst
      waitcnt(clkfreq*2)                                         'wait
      dira[12]~                                                  'set 12 to input
      repeat
        if tInc >< 0                                             'If tInc has been set
         pst.str(string(13, "tInc=="))                             '
         pst.bin(tInc, 32)                                         '
         pst.str(string(13, "dInc=="))                             'report config values
         pst.bin(dInc, 32)                                         '
         pst.str(string(13, "tC=="))                               '
         pst.bin(tC, 32)                                           '
         pst.str(string(13, "*****************************"))    'indicate begining of next loop
          repeat                                                 'repeat forever
            repeat until dira[12]==1                             'do nothing until dira[12]==high
            'do nothing
            i++                                                  'increment i
            pst.str(string(13, "Pulse#"))                        'display pulse number using i as index
            pst.dec(i)                                           '
            pst.str(string(13, "LS=="))                          'report LS of pulse#i
            pst.dec(LS[servoPin])                                '
        elseif tInc == 0                                         'If tInc has not been set
         pst.str(string(13, "servo not yet configured"))            'report "servo not yet configured"
    DAT
      tInc long 0
      dInc long 0
      tC long 0
      LS long 0[32]
      start long 0[32]
    I'm sure there is some fundamental flaw in my approach here; of course Whatever advice you have would be greatly appreciated.
    PS: given the delay between posts, should I start a new thread?
  • JonnyMacJonnyMac Posts: 9,836
    edited 2012-09-14 09:15
    Only if you want to be annoying! ;) It's considered poor forum etiquette to start multiple threads on the same topic. Assume that you are the problem; perhaps you haven't provided enough information or details (the root of specification is 'specific'). Maybe you've been given viable guidance and just cannot or will not grasp it at your current level of competence.
    I think I pointed out that I and others have written viable servo drivers. I would suggest walking away from your project -- only for a moment -- to disect what others have done. Then go back. I use this trick on myself all the time. When I'm stuck, I turn to another technical bit of work to get my mind moving again. You may find, as I frequently do, that the time spent away allows you to see your project in a new light when you come back to it.
    I have downloaded a handful of servo drivers including yours [JonnyMac] and have dedicated a significant amount of time to trying to understand them. My own driver is merely the culmination of what information I have gleamed from other drivers. I am aware of my poor level of competency and the likely hood that I am missing something obvious. But rather than bang my head against the keyboard, I figured it was easier to ask for help.
    PS: I asked about new threads because I was un-sure of the existing forum etiquette.
