Help understanding how to handle a return value — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-09-09 13:09 in Propeller 1
If I have a method that will return a value how do I handle the value on the return to the calling method?
For instance:
pub some_method  |  response
  some code
  if this happens
    response := 1
  else
    response := 0
  return response
In the calling method I call some_method but I don't know how to bring in the response. Hope you understand what I'm asking.
Thanks.
Don
  • Don MDon M Posts: 1,654
    edited 2012-09-09 08:34
    A little more clarification.
    My main code might be this:
    Pub  Main
      some code
      some_method
      some more code
    So after I return from some_method how do I react to the value returned?
    edited 2012-09-09 08:51
    HI Don,
    for this yofine a global long
    The call for your method is then used as assignemt to this variable see code example below
    VAR
      long MyGlobalVarForResponse
    PUB Main
      MyGlobalVarForResponse := some_method
    if MyGlobalVarForResponse == 0
      Do that
    else
      Do this
    pub some_method  |  response    some code   if this happens     response := 1   else     response := 0    return response
    best regards
    Stefan
  • JonnyMacJonnyMac Posts: 9,800
    edited 2012-09-09 08:52
    Easy-peazy:
    someValue := some_method
    It's important to remember that a method can only return one long. If you're clever, you can pack it as two words or four bytes. If I need a method to affect multiple values I pass the starting address of those values to the method.
    edited 2012-09-09 10:03
    Don_M,
    In addition to Jon's comments, you can eliminate the return statement by making response the automatic return value. Just place a colon ([noparse]:[/noparse]) in front of its declaration, instead of the vertical bar (|).
    pub some_method  :  response
      some code
      if this happens
        response := 1
      else
        response := 0
    edited 2012-09-09 12:47
    Thanks guys. I have tried all 3 implementations and now understand.
    A method in spin is actually a function returning a long value. Allways.
    The implicit return-value (if you do not return anything with RETURN) is a variable called RESULT.
    So if you not retun anything by yourself (not using RETURN statement) you can imagine a RETURN RESULT at the end of your method even if it is not standing there.
    The variable RESULT is allway defined and in OPPOSITE to all local variables you declare after the | it is initialised to 0. ALL OTHER local Variables you declare ARE NOT initialised to anything. This one got me a couple of times until I found out.
    So
      some code
      if this happens
        response := 1
      else
        response := 0
      return response
    is the same as
    pub some_method
      some code
      if this happens
        RESULT:= 1
      else
        RESULT:= 0
    And if you like to rename the implicit return-value RESULT to somethin else, to make your code more self-documenting you can do this also - as Phil showed using a : after the method-definition and before the |
      some code
      if this happens
        response := 1
      else
        response := 0
    StefanL_38 is not right in saying you need a global variable to read the result of a function/method-call, you do not. You can use a local variable or not even a variable at all - since you can use the return-value as is.
    so this will work without a global variable
    PUB Main | myLocalVarForResponse
      myLocalVarForResponse:= some_method
    if myLocalVarForResponse == 0
      Do that
    else
      Do this
    and this without any variable
    PUB Main
    if some_method== 0
      Do that
    else
      Do this
    I hope this will answer your question.
    Enjoy!
