Best way to use waitpeq to check the status of a range of pins — Parallax Forums
gergtechgergtech Posts: 7
edited 2012-09-07 18:34 in Propeller 1
Hello,
I'm obviously new....but I'm trying to pause the my program until pins ina[1] though ina[20] = 0 using waitpeq.
Ive tried to use the Propeller manual to figure this out, but I don't get the examples.
This is probably a Prop 101 question,
Thank you for the help
Greg Pfrommer
Atlanta Ga
  • JonnyMacJonnyMac Posts: 9,800
    edited 2012-09-07 13:21
    If you're wanting to hold the program until all those pins clear you can do something as simple as this
    repeat while (ina[20..1])
    Yep, one line. If any pin is high (1) the expression will evaluate as true.
  • gergtechgergtech Posts: 7
    edited 2012-09-07 13:23
    THAT'S IT, Thank you, I knew I was trying to do this the hard way.
    I so need to go back to school?
    edited 2012-09-07 13:48
    School is one place (of many) to learn. There's lots of good stuff posted in these forums by people who go beyond theory into practical, real-world applications.
    edited 2012-09-07 14:36
    gergtech,
    Welcome to the forum!
    Jon's solution works and is easy to grasp, since it's able to use the ina[20..1] notation. However, you can use waitpeq, if you like, and it does save power consumption during the wait. Do it this way:
    waitpeq(0, $001f_fffe, 0)
    The first argument to waitpeq is the pin state you're waiting for; the second argument, a mask whose "one" bits identify which pins of ina you're checking. The third argument should always be zero, since there is no inb.
  • lardomlardom Posts: 1,659
    @gergtech, Welcome. The speed at which you will learn here may surprise you. The level of knowledge and experience in this community is hard to match. Have fun.
