Nordic nRF24L01+
I plan to use the nRF24l01+ to communicate from a PIC based system to a PC fitted with a standard WiFi dongle.
The PIC will be emulating a keyboard scanner, similar to the HT82K629.
This produces a clock and data output.
I don't understand how the RF module will transmit these two signals.
I know this is standard practice as I have seen similar arrangements in use.
Any advise will be appreciated.
First, I don't think it's possible to do Wifi (a suite of communication protocols) over the nRF24L01+ (hardware), despite both being 2.4GHz.
Next, a standard WiFi dongle will not be able to implement a HID type. You'd need something else.
I would recommend transmitting the keycodes as follows:
PIC->nRF24L01+->nRF24L01+->PIC->Computer
You say this is "standard practice". Can you provide links?
If you need help with implementing this specifically on the Pic, you'll want to try a different forum with more expertise. These Parallax forums are for BS2, SX, Javalin, and Propeller processors and the Parallax hardware.
Sorry I am on the wrong forum, I came across this while searching about Nordic products.
But as a reply.
My client has given me a PCB assembly which he has taken out of a wireless PC keyboard.
The board has a SPCP02, key matrix scanner, this produces clock and data outputs. A nRF24L01 and a small EEPROM.
I believe the EEPROM some how configures the nRF24L01.
Going back a stage, if you take the clock and data signals and feed them into a standard PC USB socket, no additional hardware of software, it behaves as a PC keyboard.
This board does the same thing via RF and uses a standard of the shelf USB dongle.
Hence my question, how does it do it?
Best regards,
I'm unconvinced that you can use the nRF24L01+ to directly interface to WifI signals or use it to emulate as a HID. The nRF24L01+ has only SPI as the interface method (not keyboard interfaces, or Ethernet, or anything else). Here is one appnote that describes the system I did above: http://www.atmel.com/Images/doc7650.pdf Note that it has two nRF24L01+s, and two processors.
Of course, you shouldn't take my word for it. Pull out a scope or a digital logic analyzer and check the signals. If you use something like the Logic16 then it will be able to automatically decipher the protocol. (ps: if you do that, then post back here! I'm curious about this now).
