Realtime wireless motor rotation using handheld encoder system.
Hello,
I'm new to the forum but have been using BS for a few years now. The title may have not made my project clear but this is it:
I need to build a handheld controller which is powered by battery and not connected to a computer, for the beginning the controller will have a knob to control a motor movement, the control will be 1-1, meaning that the amount a rotate the knob on the control the same amount will reflect on the motor, and it must be bi-directional, think of it as a knob that turns a wheel...but wireless. The precision of this system must be really high and realtime, the distance between the handheld controller and the motor controller will be max 10 meters so the fastest available link with the lowest power consumption can be used, which I presume is Wifi.
My main question is: which is the best solution for the knob part, a rotary encoder or is there something better?
Any help will be appreciated!
A potentiometer and a pair of XBees would work, if the knob does not need to turn continuously.
Describing the needed precision as "really high" is not helpful. Can you quantify what precision you need?
Regarding speed, the eye doesn't see much faster than 1/30th of a second frame, so having a communications rate of the serial interface that is something like 19200 Baud is going to be able to respond faster than you can see or physically move.
