Using a BOE as a USB2SER
Can I use the BOE as a USB to SERIAL programmer?
I have an MP3 module that I accidentally switched to 115200 Baud. Since the BS2 max baud is 9600 I can't use it to send the HEX command to the MP3 module at 115200 to switch it back to 9600 baud. Can I connect my PC to the BOE and the BOE directly to the MP3 Module and then send a HEX command to switch it back to 9600 baud? If so, how do I wire it up and what software should I use to send the HEX command?
This was answered in post #13 of the followign thread.
http://forums.parallax.com/showthread.php?141969-Audio-Playback-with-the-Basic-Stamp&p=1124483#post1124483
