Problem with decx method from Simple Numbers — Parallax Forums
Don MDon M Posts: 1,653
edited 2012-09-06 08:16 in Propeller 1
I am trying to display on PST a series of numbers in decimal form. I wanted each number to only be 2 digits (00 - 99). So I tried using the decx method and I only get the 16 bits (2 blocks of 8) at the beginning of the line and the rest is blank where I would expect it to be 00 00 00 .... 10 10 10 10 or what ever values are containd in s. The TubeFull data prints but the TubeStatus is blank.
Here's the decx method contained in term object:
PUB decx(value, digits) | div                           ' Added Sept. 6, 2012
'' Returns pointer to zero-padded, signed-decimal string
'' -- if value is negative, field width is digits+1
  clrstr(@nstr, MAX_LEN)
  digits := 1 #> digits <# 10
  if (value < 0)                                        ' negative value?
    -value                                              '   yes, make positive
    nstr[idx++] := "-"                                  '   and print sign indicator
  div := 1_000_000_000                                  ' initialize divisor
  if digits < 10                                        ' less than 10 digits?
    repeat (10 - digits)                                '   yes, adjust divisor
      div /= 10
  value //= (div * 10)                                  ' truncate unused digits
  repeat digits
    nstr[idx++] := (value / div + "0")                  ' convert digit to ASCII
    value //= div                                       ' update value
    div /= 10                                           ' update divisor
  return @nstr
And here's my code for printing:
pub Tube_Inventory  | s, pos
  TubeFull := 0                                         ' Clear tube full flags
  repeat pos from 0 to 15                               ' Cycle through all 16 coin tube values
    if TubeStatus[pos] => $32                           ' Check to see which coin tubes are full
      TubeFull |= 1 << pos                              ' Set tube full flag for tubes reporting as full
  repeat pos from 1 to 0                                ' Display TubeFull and TubeStatus
    s := TubeFull.byte[pos]
    term.bin(s, 8)
    term.tx(32)
  repeat pos from 15 to 0
    s := TubeStatus[pos]
    term.decx(s, 2)                                     ' Show decimal value of tube inventory
    term.tx(32)
  term.tx(13)
Prior to using the decx method I was just using term.dec(s) and it would print out fine.
Help!
Thanks.
Don
