Byte array indexing help needed — Parallax Forums
Don MDon M Posts: 1,654
edited 2012-09-06 05:51 in Propeller 1
I have 2 byte array variables.
The TubeStatus[16] array contains byte values that are the equivalent of inventory counts of the 16 different bytes in the array numbered 0 - 15.
The TubeFull[2] array is a 2 byte array that is used as a flag to indicate which of the 16 tubes may be full.
What I am trying to do is read the value of each of the 16 bytes from TubeStatus and compare them to the number $32 Hex. If they are at $32 or more than I want to set the individual bit in TubeFull that corresponds to each byte from TubeStatus. In other words TubeStatus byte [0] would control TubeFull bit 0, TubeStatus byte [1] would control TubeFull bit 1, etc.
Here's the code I was trying but can't get to work:
pub  Tube_Inventory  | s, pos
  repeat pos from 0 to 15
    s := byte[TubeStatus][pos]
    if s => $32
      if pos < 8
        byte[@TubeFull][0] := (%1 << pos)
      else
        pos := pos - 8
        byte[@TubeFull][1] := (%1 << pos)
I had thought about declaring TubeFull as a word and working some magic on shifting bits through the word but then I open another can or worms trying to break up TubeFull into 2 bytes so that it can be transmitted as 2 bytes instead of 1 word. My transmit method has a tx_block command but I can't seem to make it work.
pub  tx_block(pntr, n, ds)
'' TX block of n bytes / words
'' -- address of block is at pntr
'' --ds is data size: 1 for bytes, 2 for words
  repeat n
    if (ds == 1)
      tx(byte[pntr++])
    else
      tx(word[pntr])
      pntr +=2
Any and all help much appreciated.
Thanks.
Don
    edited 2012-09-05 20:29
    Don,
    Quick first impression: your statement s := byte[TubeStatus][pos] should read s := byte[@TubeStatus][pos].
    BTW, if TubeStatus is delcared as a byte array, you can dispense with byte[@TubeStatus][pos] and just write TubeStatus[pos].
  • AribaAriba Posts: 2,697
    edited 2012-09-05 20:30
    Declare TubeFull as a long and spilt it in bytes when you send it, that is much simpler.
    Here is how Iwould do it:
    pub  Tube_Inventory : i
      TubeFull := 0
      repeat i from 0 to 15
        if TubeStatus[i] => $32
          TubeFull |= 1<<i
    'and in your send routine, send TubeFull bytewise:
      tx(TubeFull.byte[0])
      tx(TubeFull.byte[1])
    Andy
  • BitsBits Posts: 414
    edited 2012-09-05 21:56
    • Mine requires no array :)
    wrong posting, Dang pill confused me.
  • Don MDon M Posts: 1,654
    edited 2012-09-06 04:06
    Don,
    Phil- actually I did have the ampersand in my original code. Just forgot to type it in this posting. Thanks for the shortcut tips however.
    Ariba- Thanks for your suggestion. I'll give it a whirl and see how I get along. Thanks again.
    Thanks everyone. It works great!
