using buttons on the quickstart
I know I can just get my own keys, and either wire them separately, or use a keypad, and just knock off extra keys, but the quickstart already has 8 buttons on it, and I'm looking to take advantage of that if I can.
What I'd like though, is to have regular keys on top of the board, that when pressed will "touch" the quickstart provided buttons, and trigger them just as if they'd been hit with a finger. Pressing times would be in the fractions of a second, so don't know if this would be practical using the quickstart provided buttons, but I guess some experimenting would tell me. I'm mainly looking to find what materials would trigger the buttons, since it'd have to be something added to the bottom of whatever is being used as keys on top of the board, (such as keys off a regular keyboard, or maybe just rubber pads or something).
It may be better to use a separate keypad, but modifying a regular keypad for what I have in mind wouldn't be very easy, which is why I was hoping to use individual keys (anyone know where to get blank keycaps?)
So, I guess I'm wondering if anyone has tried this kind of thing, and if so, what worked, what didn't, and what (if anything) would you folks recomend for such an application.
Thanks for any help.
If you're not going to use the built in buttons, then just don't use them, ya know?
How much keyboard do you want?
If you don't want to "smutch" the pads with tin-solder you can also use the appropriate pins on the connector.
or will holding it down cause ina a to flip back and forth from low to hi real quick, in effect repeating the same action multiple times like on a pc kb... i really doubt this is how they work if thats what your scared of.. i could be wrong though
HA ha ha ha ha! I love hearing stuff like this. Flippin brilliant.
It's not just a matter of implementation? The buttons need to be de-bounced.
Have a look here: http://www.parallaxsemiconductor.com/sites/default/files/parallax/TouchButtonsLEDDemov1.0_1.zip
