count to determine boe bot action
maybe this cant be done the way i want it to. or maybe it is the long way of doing it. but here goes.
I have done all the basic programs in the Robotics with the Boe-Bot book ver 3.0.
what i want to do is set the boe-bot up so that all the basic programs are all loaded verses having to carry my laptop with me to display the diff functions. The idea is to have a script at the beggening that will count how many times the tactical whisker is tapped. then have the boe-bot use the tap count to start a sub routine. i have used a couple of diff count methods but i have yet to over come the contact bounce.
here is what i think is my best script. i would much rather have a percise count so i can have many more options.
If you're already using the Boebot's IR proximity sensors, you have all the hardware you need. You can use those same sensors to receive IR signals from a TV remote control. It's all in the Boebot book.
