Defcon Badge + PIR sensor
http://learn.parallax.com/kickstart/555-28027 <<
so i was able to get it working with my normal dev board (p8x32a)
http://pronto185.com/parallax/animation_1346611479916.gif
LEDs on = movement, off = no movement
(changed code a bit from whats shown on the gif, but still same concept)
now when i try to do this on my defcon badge , it's not working.
i have it connected correctly (used one of those pinout diagrams posted)
http://i.imgur.com/QjwrS.jpg
OBJ
pst : "Parallax Serial Terminal" ' Use Serial Terminal object
CON
_clkmode = xtal1 + pll16x ' Set clock mode
_xinfreq = 5_000_000
VAR
byte state ' Variable for storing PIR output
PUB PIR
dira[17] := 1
dira[18] := 1
dira[22] := 1
dira[21] := 1
outa[17] := 0
outa[18] := 0
dira[0] := 0 ' Set pin 0 to input
pst.start(115200) ' Start Terminal at 115200 baud
pst.str (string("Warming up..."))
waitcnt(clkfreq * 20 + cnt) ' PIR "warm-up" time
pst.clear ' Clear the screen
repeat
state := ina[0] ' Save state of PIR Sensor
pst.home ' Move cursor to upper left
pst.str(string("IN0 = "))
pst.bin(state, 1) ' Display results
waitcnt(clkfreq/200 + cnt) ' Small delay\
if state == 1
outa[17] := 1
outa[18] := 1
outa[22] := 0
outa[21] := 0
else
outa[17] := 0
outa[18] := 0
outa[22] := 1
outa[21] := 1
