Propeller Platform / Arduino Shields /
Rather than hijack the other thread...
I think Martin hit a home run with his latest projects.
"Arduino Shield Adapter" and "Arduino Shield Compatible" offer Propeller-heads
a simple way to adapt Arduino Shields to their projects.
If there is an Arduino shield that you want to use, here are two ways to hook up.
The ASA adapter fits on any of the Propeller Platform boards and allows an Arduino shield
to be plugged into a Propeller Platform.
If you are up and running on a Propeller Platform already the adapter may be just the trick.
If you need uSD, pick a Platform board that has one rather than use a shield.
Save that for the other stuff...
This is a Motor Control Shield - on an ASC board.
Two PWM brush motor circuits (main drive) and 13 servo channels.
It may not be a whole robot brain, but it could be a very serious lobe.
