Xbee/Propeller battery reccomendations
I am building a remote control unit using the 60mw Xbee pro. The unit will be housed in a handheld enclosure about the size of a large digital VOM. There is a small slanted front panel area for the Parallax 2 x 16 serial display, a two axis joystick also Parallax using MCP 3202 A/D to read the Joystick. The Propeller is a "Spin Studio" board with both 5VDC and 3.3 VDC available.
I have already resigned myself to having the battery external to the enclosure either mounted to the bottom of the unit or maybe even a tether to a belt mount etc.
I have seen a lot of print regarding Li-Po batteries but I have no experience at all with them.
Take me to school on how to power this handheld controller with the "high power" Xbee pro...
Thanks for reading...
Mike B.
Mike B.
http://incredulist.blogspot.com/p/cypherbot_23.html
I got the XBee's 3V from the system 5V by using 3 silicon diodes in series. I also put an LED on that output for a minimum draw and as a 3V good indicator.
I didn't use any fancy batteries, just a 9V alkaline as source/V_in for a 7805SR (which has good/great efficiency even at low current.) Batteries, unlike many other things these days, have become less expensive [or is it just me?]
