Propeller to Mosfet Driver connection - do I need resistors? — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2012-08-31 18:31 in Propeller 1
I would like to connect a Propeller chip to a mosfet driver (http://www.ti.com/lit/ds/symlink/ucc27321.pdf), and I know that when I drive a mosfet directly from a prop, I need to use a couple of resistors as shown in this diagram by Phil Pilgrim:
But are these same resistors needed when the Propeller drives a mosfet driver? I'm guessing these resistors are needed but I'm not really sure.
Thanks.
  • jmgjmg Posts: 15,200
    edited 2012-08-31 18:24
    It is common for MOSFET drivers to include resistors, to default pins on floating drive, but that one does not.
    So you need an external one.
    jmg wrote: »
    Thanks, I just wanted to make sure I understood the diagram.
