prop chip and increasing frequency using crystal oscillator? — Parallax Forums
purplemonkeypurplemonkey Posts: 89
edited 2012-09-01 10:37 in Propeller 1
Sorry another newbie question, if you plugged the transmit pin on the prop chip running fm transmitter program into a crystal oscillator say at 1ghz and then to an antenna would it broadcast the signal at 1ghz?
    edited 2012-08-31 18:13
    No. The crystal needs to be part of a circuit that causes it to oscillate. Putting an FM signal at 88 - 108MHz into it will not make it oscillate at 1GHz.
  • purplemonkeypurplemonkey Posts: 89
    Thanks just wondered!
