pc to arduino using Xbee
hi...
I have arduino mega 2560 R3, Xbee arduino shield, 2 of Xbee modules (modem type XBP24BZ7), USB-XBEE Adaptor. I have configured first Xbee as coordinator at and second one as end device at. I have succeeded in sending string from arduino to X-CTU terminal (Xbee software) using this code
But I can not receive any string from X-CTU terminal to arduino. I have tried many arduino codes such as :
and this too
But receiving never works.
What should I do to solve this problem?
Best regards
void setup(){ Serial.begin(9600); } void loop(){ // handle serial data, if any Serial.println("hello world"); }
// this is where we will put our data int myData = 0; void setup(){ Serial.begin(9600); } void loop(){ if(Serial.available() > 0){ Serial.println(333); myData = (int)(Serial.read()); Serial.println(myData + 777); delay(1000); } }
and this too
#include <XBee.h> XBee xbee = XBee(); void setup() { xbee.begin(9600); } void loop() { //attempt to read a packet xbee.readPacket(5000); if (xbee.getResponse().isAvailable()) { // got something Serial.println("something"); if (xbee.getResponse().getApiId() == ZB_IO_SAMPLE_RESPONSE) { xbee.getResponse().getZBRxIoSampleResponse(ioSample); Serial.print("Received I/O Sample from: "); Serial.print(ioSample.getRemoteAddress64().getMsb(), HEX); Serial.print(ioSample.getRemoteAddress64().getLsb(), HEX); Serial.println(""); if (ioSample.containsAnalog()) { Serial.println("Sample contains analog data"); } if (ioSample.containsDigital()) { Serial.println("Sample contains digtal data"); } // read analog inputs for (int i = 0; i <= 4; i++) { if (ioSample.isAnalogEnabled(i)) { Serial.print("Analog (AI"); Serial.print(i, DEC); Serial.print(") is "); Serial.println(ioSample.getAnalog(i), DEC); } } // check digital inputs for (int i = 0; i <= 12; i++) { if (ioSample.isDigitalEnabled(i)) { Serial.print("Digital (DI"); Serial.print(i, DEC); Serial.print(") is "); Serial.println(ioSample.isDigitalOn(i), DEC); } } } else { Serial.print("Expected I/O Sample, but got "); Serial.print(xbee.getResponse().getApiId(), HEX); } } else if (xbee.getResponse().isError()) { Serial.print("Error reading packet. Error code: "); Serial.println(xbee.getResponse().getErrorCode()); } Serial.println("receiving not work"); delay(1000); }
Best regards
