Do solar storms benefit earth?
The Mars rover and Neil Armstrong have me thinking about space. The Science Channel had a program which described the earth's core as a dynamo, an effect created as the earth rotates around a liquid metal core. The dynamo produces the poles which deflect the ion cloud from the sun.
In the video at 3:17 and again at 3:31 the solar wind is funneled into the poles. This is an electrical/magnetic interaction. I know this wreaks havoc on the power grid and our communications but does this have a benefit on the earth itself?
[video=youtube_share;N5utQxtma2U]
So, the combination of global warming and wide power outages could be a 'perfect storm' condition.
If the same storm happened now, mayor problems.
Though a Gamma-ray burst from a distance place in Universe (last around 30 seconds),
will pretty burn everything to a crisp on that half side of earth, unless you are under 10 feet of dirt.
Only 1% chance that will happens in earths lifetime, but when it do there is no warning as it travels at the speed of light.
Solar storms happen, along with many other phenomena.
Earth does know or care it just happens.
Perhaps we humans worry about such things. But there is no special reason we have to be here.
could the particle energy be collected into a giant capacitor for instance?
Do a search for the Space Shuttle space tether experiment.
http://www-istp.gsfc.nasa.gov/Education/wtether.html
http://en.wikipedia.org/wiki/Electrodynamic_tether
There's the magneto telluric current thing, if that's what you're talking about.
http://en.wikipedia.org/wiki/Telluric_current
As for the protons that come spiraling down earth's magnetic field lines at the poles, I suppose if you could mount a plate high enough, you might get some currents. After all, that's what powers the aurora, I believe. I don't think a very large percentage of that particle energy ever makes it near the ground, however. I'm guessing that currents induced by magnetic fluctuations would probably be your best bet for sucking energy from a solar storm. But I'm no expert.
-Tor
