IR object detection with 3 feet of wire
I'm trying to setup two IR detection circuits. One of them is on a BOE board and the other one is about three feet away on a bread board that is hooked up to the BOE board via P4, P6, Vss, and Vdd using 22 AWG hookup wire. When I upload the code to my STAMP, sensor two (irDetectTwo) works on the bread board that is three feet away but sensor one (irDetectOne) on the BOE board doesn't work. I don't see a short anywhere. If I remove all of sensor two components from P4, P6, Vss, and Vdd then sensor one works. Sensor one is hooked up similar to what is shown on page 231 (Robotics with the Boe-Bot). Am I drawing too much current? Do I need a capacitor?
' {$STAMP BS2e}
' {$PBASIC 2.5}
irDetectOne VAR Bit
irDetectTwo VAR Bit
DO
FREQOUT 2, 1, 38500
FREQOUT 6, 1, 38500
irDetectOne = IN0
irDetectTwo = IN4
IF (irDetectOne = 0) THEN
DEBUG "Sensor1"
ENDIF
IF (irDetectTwo = 0) THEN
DEBUG "Sensor2"
ENDIF
PAUSE 100
LOOP
' {$STAMP BS2e} ' {$PBASIC 2.5} irDetectOne VAR Bit irDetectTwo VAR Bit DO FREQOUT 2, 1, 38500 irDetectOne = IN0 FREQOUT 6, 1, 38500 irDetectTwo = IN4 IF (irDetectOne = 0) THEN DEBUG "Sensor1" ENDIF IF (irDetectTwo = 0) THEN DEBUG "Sensor2" ENDIF PAUSE 100 LOOP
