Logitech introduces a Washable Keyboard — Parallax Forums
    edited 2012-08-24 17:37
    I'm kind of surprised it's not wireless. I think washable (water resistent) and wireless would be a good combination for a lot of applications.
  • piguy101piguy101 Posts: 248
    edited 2012-08-26 16:02
    Neat concept, but I don't think it will catch on because I don't keep food by my computer.
    edited 2012-08-26 20:35
    piguy101 wrote: »
    Actually it should, at least in the medical community. I have spec'd a couple of these "cleanable" keyboards in the past for the ORs, but they were the flat wipables that the "keys" felt like Smile on a flat surface; but infection control is the name of the game. I would wonder just how clean they can be and how much cr@p would stay / grow inside of the device. This may get forwarded to risk and IT for consideration. PACS team as well.
    edited 2012-08-27 09:30
    I could use one. It is just 25 or so years too late.
    For medical use, it would likely have to be up to being washed with alcohol -- not just water. Recently I destroyed the screen on my Toshiba netbook as I washed in with alcohol - a big no-no. I am just supposed to use a damp soapy tissue.
    edited 2012-08-27 10:08
    Pah washable! it didn't even get passed the fast spin cycle let alone the tumble dry.
    edited 2012-08-27 11:24
    The webpage has the following footnote:
    * Hand wash only. Use mild soap and a soft cloth in warm water less than 30cm (11 inches) deep and less than 50°C (120°F). Do not wash in dishwasher. Do not use abrasives, alcohol, solvents or harsh detergents. Do not submerge the USB cable. Follow washing instructions in the Quick Start Guide.
    It doesn't say if you can wash it while it's plugged in, but I assume it has to be unplugged. I believe Logitech also sells a membrane you can put over your keyboard so you can spill-proof an existing Logitech keyboard.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-08-27 11:58
    Funny, that's how I've always washed electronic stuff. Never had any problems.
    edited 2012-08-27 11:59
    RDL2004 wrote: »
    Did you use rinse aid? :smile:
    edited 2012-08-27 12:31
    Just regular dish cleaning liquid, usually Cascade brand, followed by a separate rinse in distilled water. I normally won't let it run for the full cycle and I don't use the heated dry, I just let stuff air dry for several weeks.
    edited 2012-08-27 12:36
    Actually joking aside i'm surprised that the salt content doesn't do the damage, obviously well sealed.
    edited 2012-08-27 15:37
    RDL2004 wrote: »
    Looking at an old document on Tektronix, they used to power wash scopes coming in for maint/refurb.
    edited 2012-08-27 16:08
    You have to use a little common sense. I wouldn't just stick a clock radio or a TV straight into the dishwasher. Keyboards, mouses, bare circuit boards (such as video cards), open-frame power supplies, items like that are all I've ever washed. I'd be afraid to run something with delicate parts such as an LCD display through the dishwasher.
    Usually anything that's going into the dishwasher has to be pretty dirty before I even consider doing it. There's always the possibility of the item suffering permanent damage, though I've never had a problem. Electronic components are pretty tough - consider what they are subjected to during the manufacturing process. A little soap and water isn't likely to hurt them as long as everything is thoroughly dry before you power them up again.
    edited 2012-08-28 01:06
    Frankly, electronics have become more fragile and people have just had to accept that is what is available.
    For many decades, I never purchased a color TV. People would happily give away broken ones and nearly all were just dirty inside, so carbon had built up to conduct high voltage on the outside of the tube. A good washing with a few cans of spray cleaner and the TV was working fine until it got dirty again.
    TV repair and computer repair are dying occupations - no parts, no documentation, and specialized construction.
    The fact that this keyboard won't stand up to much water or cleaning with alcohol indicate it really is more of a marketing ploy than a real improvement in product. Keyboards are some of the dirtiest electronic devices ever invented and could greatly benefit from being regularly washed, but I guess I will just continue to buy cheapo replacements. To me, Logitec has never really seemed to deliver the increase in value for the premium they charge. They just seem to be rebranded OEM.
    BTW, I also wash the inside of my computer about once a year with spray tuner cleaner, including the power supply. After all, when the heat starts to build up from dust and debris, the unit struggles and then fails.
    The local Toshiba repairman was quite offended when I mentioned that I would clean the inside of my netbook with a spray cleaner. He wanted me to buy a whole new unit and not replace the screen.
    edited 2012-08-28 01:24
    piguy101,
    ...I don't keep food by my computer.
    So when do you eat? :)
  • doggiedocdoggiedoc Posts: 2,255
    edited 2012-08-28 04:04
    I eat and drink by my computer all the time. This stems from the fact that given idle time I either eat, sleep, sit down at the computer, or some combination of the three. :D
    edited 2012-08-28 04:07
    Doesn't everyone rest their pizza slice against the space bar?
    edited 2012-08-28 09:58
    skylight wrote: »
    Nope! Doesn't last that long!!!
    edited 2012-08-28 10:01
    The main reason I'm glad I'm not a touch typist?
    NO productivity loss when eating and working!! :0)
    edited 2012-08-28 19:32
    One BIG hang up is BGA chips and hard water residue ..
    some QFP chips are a pain too....
    but Yes I wash MoBo's all the time ...
    edited 2012-08-28 21:38
    skylight wrote: »
    Only when seated in front of a specific SUN box........:lol:
    edited 2012-08-29 00:33
    because of language differences I'm presuming you are referring to expensive workstations :smile:
    Which makes me think of the heat generated by the CRAY equipment and those extravagant coolers they deployed that had seating incorporated in them perhaps an ideal pizza warmer?
