Using cogstart from an XMMC mem model program — Parallax Forums
sssidneysssidney Posts: 64
edited 2012-08-24 11:09 in Propeller 1
hi,
Is it possible to successfully call cogstart from a XMMC program?
In case it is OK - here's my test code:
#include <stdio.h>
#include <propeller.h>
extern _Driver _SimpleSerialDriver;
_Driver *_driverlist[] = {
  &_SimpleSerialDriver,
  NULL
long dummyCogStack[128];
void dummy1(void *dum1)
  while(1);
int dummyArg = 123;
int main(void)
    int dummyCogId;
   waitcnt(CLKFREQ+CNT); // pause for terminal to open
   printf("starting in cog %d\n", cogid());
    dummyCogId = cogstart(&dummy1, &dummyArg, dummyCogStack,  sizeof(dummyCogStack));
    printf("cogstart %d\n", dummyCogId);
    while(1);
    return 0;
I get the following output when using XMMC mem model:
starting in cog 3cogstart -1
All is OK when using LMM:
starting in cog 0cogstart 1
I am using a C3 board.
  • ersmithersmith Posts: 6,286
    sssidney wrote: »
    hi,
    No. Unfortunately, the current XMM kernel and cache mechanism does not allow multiple COGs to run XMM C code at the same time. We're looking into improving this.
    You can run COG C code on the other cogs in XMM mode.
