Basic Stamp, Linux Shell, Serial communications, Help
Hi all,
I'm trying to get my Linux shell (Ubuntu 12.04.1) to communicate with my Basic Stamp (BS2) by simply writing to /dev/ttyS0 (with something like CAT). At the moment I've managed to get my Stamp to respond to data sent through the terminal, but it doesn't respond the way I think it should. Here is my Basic Stamp code:
' {$STAMP BS2}
' {$PBASIC 2.5}
sData VAR Byte
SERIN 16, 84, [DEC sData]
i VAR Byte
FOR i = 1 TO sData
HIGH 1 ' I have an LED connected to pin 1
PAUSE 250
LOW 1
PAUSE 250
NEXT
The trouble is that the number of blinks of the LED are unpredictable. I type in "1" (using the command "cat > /dev/ttyS0" and then typing the number), it blinks twice. I type in "1" again, it blinks nine times, now eight, two again, but never one. I have the port set to the same baud rate as my Stamp, and I've set no parity and 8-bit on the port as well; or, at least I think I have. I used the command "stty -F /dev/ttyS0 -parenb cs8", and I set the baud rate with setserial.
I don't understand the problem. I tried converting from ASCII the hard way (input-48) but that didn't work, I tried using DEBUGIN instead of SERIN and that didn't work. However, everything does work correctly when I use the Debug window on the Basic Stamp Editor.
SB316
' {$STAMP BS2}
' {$PBASIC 2.5}
sData VAR Byte
i VAR Byte
FOR i = 1 TO sData
PAUSE 250
LOW 1
PAUSE 250
NEXT
SB316
hth.
