Hardware Communication failure Error
My parallax system is generating this annoying message when I try to RUN - Load to the BS2 a program:
"Hardware communication failure, check prog cable and power supply"
The system try to load the program gets to any percentage , it does not matter it failed........ Eventually it works when I continue to try again and again.
I have disconnect other circuts, try smaller program, change the 9v baterry to a new one....it does not make any difference.
I have check the forums ., since this situation had being notify before but no solution had being provided yet (as far as I can try). The USB connection is the same included in the Student kit included. My Laptop is running Windows XP.
I am in the middle of a project and will like to find a solution to this issue. Beside this issue I think your product is great.
PRPROG
PRPROG
Thanks for the reply.
No. I am using the same cable that Parallax provide with the Kit (USB connector). Why could it be the cable?
Those are supposed to be standard. Right? I will give a try any way....if I found one of those cable at home.....
Thanks Mike.
I will try another cable.Hope I find one at home.
Anyway by the program behaviour it looks like it is actually downloading the program (at least that is what is seems to happen by the percentage change) ...and then it failed. Sometimes it failed at 10% or 5%...but it can failed at 80% or even 95% of the download process. So the communication check is not done (at least from my point of view as a user) not at the start, but as the download process progress.
The message is correct. It's caused by a communications failure between the PC and the Stamp. The PC sends some data and the Stamp is supposed to respond and it doesn't. It doesn't depend on your program except that the longer your program is, the more time it takes to download and the more time there is for an intermittent error to occur.
...already try a new fresh 9v battery. The board does not have an AC Power Adapter. (sorry to highjack my own thread.)..but how do I add a suitable AC adapter plug and connection? . It would be better to used AC power instead of 9v battery. Can you point me to a previous thread were this modification was discuss. I bought the BASIC Stamp Activity Kit - Serial + USB in Radio Shack. It does not include an AC power adapter. (Item code 90005)
Wow....totally different approach....hope one of the alternative resolved the situation. I will check this USB latency setup first....then try the cable alternative if this does not work.
Great!!. If it is that simple I will plan for this change. I will be careful on the polarity.I am sure you will expect this question: Why a 7.5v output and not a 9 v? [Well at least from me a novice it is expected such a question]
Thanks.
Phil, thanks a lot. That was exactly the solution. I change the latency to 1 and voila!!! problem solved. Thanks again.
Ok. I found a 9v AC Adapter. Following your detali explanation, if I match the polarity it will work fine with the BS2 board, since it have a +5V regulator. Correct? It will not harm or damage the Stamp or the board.
PRPROG
