Problem with an TSL61 I2C Device: Code or Circuit?
So I'm taking my first swing at putting together an I2C method for the TSL2561 https://www.adafruit.com/products/439. Unfortunately I haven't gotten very far, and I'm really not sure why. As far as I can tell, I follow the instructions in the data sheet. My code is also pretty much identical to the arduino demo code, and the code my engineer friend used to test the sensor on his microcontroller.
First, I can very that the sensor is connected correctly (As far as I can tell) with Tim Moore's i2cscan object. The scan detects the sensor, and correctly returns the address.This sensor has three addresses, depending on if the address pin is high, floating or low. I2cscan always reports the correct address.
Next I try to turn on the device. I have been using James Burrows's i2cobject. From what I understand from the data sheet, and other codes, I should send the address, the control register ($80), then the power on command ($03).
This doesn't actually seem to change the value of the register. If I read back the value of the register, it is reported as 255. (Michael Greene's Basic_I2C_Driver reports -1 when Burrow's object reports 255).
Of course everything after this doesn't matter. The sensor is never turned on. The devicepresent method agrees.
I've looked over the code dozens of times. I am not sure where I am going wrong. I've also tried other i2cobjects. I've tried it with and without wait methods.
Another possibility is obviously the circuit. The fact that the i2cscan object has no problem detecting the device makes me thing the circuit isn't an issue. I am using the gadget USB platform. I tried it on the I2C bus (SCL=28, SDA=29) and general IO pins. I've tried with and without pull up resistors (1k and 1.5k) between the pins on the propeller and the pins on the sensor. I've also tried on the I2C bus on a quickstart. The result is always the same.
Another potential concern is the surface mount resistors on the breakout board (10k). I'm not really sure what those indicate. Do these resistors mean I can't use the sensor with 3.3v signals? I've got some level shifters somewhere if I need them. If the resistors on the breakout board are the problem then I have no idea how the i2cscan object would be able to get the address.
As always, I'd really appreciate any thoughts. I feel like there is something simple I am overlooking.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
SCL = 28
SDA = 29
Address = $39
' Binary 0111001
OBJ
PST : "Parallax Serial Terminal"
i2c : "i2cObject"
i2cscan : "i2cscan"
VAR
long CH0
long CH1
PUB main | data
i2cscan.i2cScan(SCL)
' Correctly finds and reports sensor address.
pst.start(115_200)
pst.str(string(13,"Starting...",13))
turnon
repeat 20
readsensor
wait
turnoff
PUB turnon | data
i2c.init(SDA,SCL,false)
' Power on sequence
i2c.writeLocation(Address, $80, $03, 8, 8)
wait
pst.str(string(13,"Power on sequence complete.",13))
pst.str(string("Register $80 = "))
data:=i2c.readLocation(Address, $80, 8, 8)
pst.dec(data)
pst.char(13)
data:=i2c.devicePresent(Address)
if data==true
pst.str(string("Device found.",13,13))
else
pst.str(string("Device not found.",13,13))
PUB turnoff | data
' Power off sequence
i2c.writeLocation(Address, $80, $00, 8, 8)
wait
pst.str(string(13,"Power off sequence complete.",13))
pst.dec(data)
pst.char(13)
if data==true
else
PUB readsensor
CH0:=i2c.readLocation(Address, $AC, 8, 16)
CH1:=i2c.readLocation(Address, $AE, 8, 16)
pst.str(string("Channel 0: "))
pst.dec(CH0)
pst.str(string(" "))
pst.str(string("Channel 1: "))
pst.dec(CH1)
pst.char(13)
PUB Wait
waitcnt((clkfreq/1000*250)+ cnt)
I saw your response earlier, and I didn't have time to reply so I just edited the post. I wanted to have a chance to look at the driver and really consider what you were saying before responding.
I did find some comments in the i2cobject that mentioned the LSB, but I didn't realize that $39 could be written in only 6 bits. Its my fault for not counting. The %aaaa_aaaa convention is a very useful one. I also completely misunderstood the use of the LSB.
The I2C scan object reports
%01110010($72) %00111001($39)
I think this is the address it scanned, then the device's address.
Reformatting the address as %0111_0010 completely took care if everything! I still have to adjust other parts of the code to get accurate readings, but at least now I am able to communicate with the device.
Thanks a lot! I knew it had to be something simple, but I was really running out of ideas.
