True PWM
Slateriesling
I was intending to use a basic stamp to control several strings of high power LEDs through constant current drivers that have a PWM controlled dimming function. Is it possible to get a 1Khz Duty Cycle PWM control signal from the controller?
If not, is it possible with one of the other chips? Propeller perhaps.
If it is not possible I may have to use drivers that are more expensive to get the same dimming capability.
Thank you
Thank you
A Propeller can do this all by itself as well as doing lots of other things at the same time.
I had a feeling that was the case from my reading but I wanted to know from the experts. I will perhaps use the Prop instead. I just had a stamp not doing anything so...
