automatically convert Spin to C or C++ — Parallax Forums
ersmithersmith Posts: 6,281
edited 2012-08-31 06:56 in Propeller 1
I've just released a new version (0.96) of the spin2cpp tool for converting spin files to C++. It now also supports conversion to plain C as well, with some restrictions. At the moment the C output is static, so only one instance of each object is allowed. I've made an effort to make the C output generic (i.e. it should generally compile with either PropGCC or Catalina) but there are still a few C++ and/or GCC specific features output for some constructs, e.g. lookup and lookdown.
Catalina already has a way to interface with spin, of course, but sometimes one may want to convert a spin file in order to benefit from the improved speed of C.
This version of spin2cpp also supports putting inline C and C++ code in spin comments. Any comment starting with {++ is assumed to be C++ (or C) code and is passed through. The intent is that a spin driver that interfaces to PASM code can have C added to it as well, so that the same spin file can be used to produce a C/C++ driver.
The download link is at:
http://code.google.com/p/spin2cpp
    edited 2012-08-21 16:49
    This is really cool.
    Thinking of a typical Spin program, there are generally a list of global variables in the VAR section. My understanding of C is that one tends not to use global variables and instead passes variables into functions and then the function returns new values. So I've been thinking of a way of writing Spin that is more like C to start with, ie no global variables.
    I'm a C newbie but I think the general concept is you pass a pointer to a variable rather than the variable. Then inside the function you now have direct access to that variable and can change it and in effect, this makes it a global variable.
    The simple case is passing one variable and returning one variable. The slightly more complex case is returning two variables. I think the general concept in Spin is to pass two pointers with the @, eg
    PUB Main | a,b
       a := 4
       b := 5
       PointerDemo(@a,@b)
    PUB PointerDemo(c,d)
       long[c] := 6
       long[d] := 7
    I'm not 100% sure that is correct but the idea is for variables a and b in the main routine to be changed by the function.
    So I ran this through Spin2CPP and it produced this code
    static pointSpin thisobj;
    int32_t pointSpin_Main(void)
      int32_t _local__0000[2];
      int32_t result = 0;
      _local__0000[0] = 4;
      _local__0000[1] = 5;
      pointSpin_Pointerdemo((int32_t)(&_local__0000[0]), (int32_t)(&_local__0000[1]));
      return result;
    int32_t pointSpin_Pointerdemo(int32_t C, int32_t D)
      int32_t result = 0;
      ((int32_t *)C)[0] = 6;
      ((int32_t *)D)[0] = 7;
      return result;
    If this is correct, one could presumably do the same thing with arrays?
  • ersmithersmith Posts: 6,281
    edited 2012-08-21 17:39
    Dr_Acula wrote: »
    Actually the VAR section in Spin is more like the member variables of a C++ class (if you use spin2cpp without the --ccode option that's what you'll see) and so they aren't global variables. Spin is an object oriented language, and it's generally considered quite acceptable for functions in the class to change class variables.
    Eventually spin2cpp will fully support objects even in C mode, and then the output of:
    VAR
      a,b
    PUB Main
       a := 4
       b := 5
       PointerDemo(6, 7)
    PUB PointerDemo(x, y)
       a := x
       b := y
    will look like:
    int32_t pointSpin_Main(pointSpin *thisobj)
      int32_t result = 0;
      thisObj->A = 4;
      thisObj->B = 5;
      pointSpin_Pointerdemo(thisobj, 6, 7);
      return result;
    int32_t pointSpin_Pointerdemo(pointSpin *thisobj, int32_t X, int32_t Y)
      int32_t result = 0;
      thisobj->A = X;
      thisobj->B = Y;
      return result;
    i.e. a pointer to the struct containing the VAR variables will be passed in as a parameter to all the functions. This is the way C++ works "under the hood"
    edited 2012-08-21 18:24
    Now that is even more clever. I like that.
    Ok, brainstorming here as I have been writing some spin code that is pushing up against the limits of what spin can do. Spin does not seem fully "object oriented". Consider an SD driver object. You can reference all its methods from the main program and that is fine. With the touchscreen however, it has been incredibly useful to create a common object called touch.spin which contains a whole bunch of useful methods. Using this object, it is possible to create a calculator program and a synth program using very little extra code. The problem is that integral to this touch.spin object is an SD driver. So the sd driver object becomes a sub-object of the touch.spin object. You can still reference the sd code from the main, but you have to do this via the touch.spin object. The next problem though is if you add in some new code that contains an object that references the sd card object. You either end up with two copies of the sd object (each of which takes about 1/3 of the hub ram), or you have to delete one and pass everything back up to the main, and then down into the tree of another object.
    With your code you just posted, does this mean C++ can pass references to objects to and from functions? If so, that makes things a lot more flexible.
    Or to put it another way, thinking graphically, Spin is like a tree with branches, and if one leaf on one branch talks to another leaf it needs to talk via the base of the tree. What would be more flexible would be to tell every leaf about a common object and then each leaf can put variables in this object and retrieve variables.
    To take a specific example, create an object like a button. Put into that object two variables and a string. Pass the object with your routine *thisobj. Then every function can use the object.
    I have this vague idea that if we take all the obex objects and convert them via spin2cpp to C objects, we could use them in ways we can't use them in spin (eg my .wav player which currently has two sd objects in it)
    Help understanding this would be most appreciated.
  • jazzedjazzed Posts: 11,803
    edited 2012-08-21 18:49
    Wow Eric.
    Combine this with your other efforts and Spin2Cpp program binaries could end up faster and smaller than Spin binaries.
    Sweet :)
    edited 2012-08-21 19:48
    @Eric, the C mode is great! I thought about requesting it a while back, but I didn't want to add more work to your busy schedule. I'm glad you had the same idea about adding the C mode.
    @Dr_Acula, I've had the same problem with multiple copies of the SD drivers. I got around it by making a modified version of FSRW that uses a pointer to a file block rather than VAR variables. It's the same idea as passing a struct pointer in C, but doing it in Spin. However, since Spin doesn't handle structures I had to copy the contents of the file block to local variables in FSRW. Fortunately, a LONGMOVE of 11 variables in Spin only takes about the same amount of time as a couple of assignment statements, so there's not much overhead in doing this.
    @Steve, when are you adding spin2cpp to the SimpleIDE? This would make Spin development very flexible, where it could be compiled to bytecodes or to the various PropGCC PASM models. Taking this one step further would allow C/C++ programs to call Spin routines that are converted by spin2cpp. This would make all of the Spin objects in the OBEX available to PropGCC programs.
    edited 2012-08-22 04:01
    Dr_Acula wrote: »
    Yes, C and C++ can both pass references to objects (in C they would be "structs") to and from functions. That is one of the major advantages of C over Spin, where the only data type is the integer.
    Of course, spin2cpp doesn't help you much here, since it's taking Spin code as input, so it will never actually take advantage of the structure passing capability. Perhaps you could use spin2cpp to convert to C (or probably C++ is better if there are a lot of objects) and then hand optimize the output to use structures.
    edited 2012-08-22 04:46
    Great news. I can see a new way of working - convert a whole lot of obex objects into C, then start using them in new and creative ways.
  • RossHRossH Posts: 5,737
    edited 2012-08-22 05:45
    ersmith wrote: »
    Nice work, Eric. On the Prop II (where the necessary Hub space will probably be available) this will be a useful option.
    By the way - lookup and lookdown are easy enough to program in C (or PASM for that matter). I've had to do this already for my own purposes - perhaps both GCC and Catalina should agree on C function prototypes for all the standard Spin functions (lookup, lookdownz, bytemove, wordfill, coginit, locknew etc etc) and then add the functions to their respective standard libraries. This would sure help people migrating from Spin to C (whether Catalina or GCC). If you want to explore this possibility further, send me a PM.
    Ross.
    edited 2012-08-22 06:35
    RossH wrote: »
    Or when used with a compiler that supports compressed instructions. It sounds like Catalina has a pretty nice CMM mode coming up, and PropGCC should get one very soon now as well.
    The common case of lookup/lookdown (when the elements are constant) is easy enough to handle -- just generate a temporary array and index into it. It's the case where the element array includes a reference to the (possibly modified) index that causes me headaches. For example:
      r := lookupz(i++ : i, 9)
    I was trying to avoid changing the libraries, although that's obviously a possibility. Using a variadic function is also another possibility, I guess -- is that what you ended up doing?
    Eric
  • RaymanRayman Posts: 16,272
    edited 2012-08-22 07:31
    Any chance this would work with something like the VGA_Demo or Graphics_Demo examples that come with the Prop Tool?
    edited 2012-08-22 07:48
    Rayman wrote: »
    It will handle the Spin code, but the result is too big to fit into hub memory without some manual changes (for Graphics_Demo, changing to single buffering; I haven't actually tried VGA_Demo yet).
    Once the various C compilers have their compressed memory models (CMM) working then there's a good chance these demos will work without changes.
    Eric
    edited 2012-08-22 08:22
    That sounds really good. I would like to try porting various lcd drivers over to C, maybe this will help...
    The LCD codes I'm interested in are very close to the VGA_Demo...
    edited 2012-08-22 08:33
    BTW: I hope we do get something like Ross's CMM for GCC too. It really removes a primary reason for sticking to SPIN...
    edited 2012-08-22 08:50
    Rayman wrote: »
    BTW: I we do get something like Ross's CMM for GCC too. It really removes a primary reason for sticking to SPIN...
    With CMM mode there may be no reason to have a Spin bytecode interpreter for P2. We would just compile Spin programs to CMM instead.
    edited 2012-08-22 08:59
    Rayman wrote: »
    Ya, it's in progress. Looks great so far. Would like to have a preview distribution when possible.
    Dave Hein wrote: »
    It's on my list. Having Eric's compressed code generator makes it more important.
    BTW, if you have access to Propeller-GCC with compressedcode, you can add the CMM model to the SimpleIDE by defining a file called memorymodels.txt in the SimpleIDE.exe folder.
    Contents of my memorymodels.txt:
    CMM
    COG
    LMM
    XMMC
    XMM-SINGLE
    XMM-SPLIT
    edited 2012-08-22 17:21
    Dave Hein wrote: »
    Hi Dave,
    I would still like to have the Spin bytecode interpreter available on the Prop II. I originally thought there might not be one, but Parallax has assured us all that there will, and I see no reason for them to reconsider that just because of CMM. Spin will always give you the smallest code sizes on the Propeller - and code size will continue to be both a Prop I and a Prop II killer for many users and applications.
    Of course, the Prop II will have more RAM than the Prop I, but even so we already run many C programs that wouldn't fit on the P2 without CMM (we currently run them using XMM). Where I believe CMM will get most traction is in entirely supplanting the need for bolting on expensive XMM hardware to both the Prop I and the Prop II.
    While the GCC team is of course entirely free to use the Catalina CMM kernel (or a derivative), I hope they decide to go their own way. I'm interested in seeing if they can do better - and I'm sure they will try hard, since Catalina has effectively stolen a march on them with CMM support :smile:.
    Ross.
    edited 2012-08-22 17:55
    RossH wrote: »
    Spin does not always give the smallest code size for all applications. It remains to be seen whether it gives the smallest code size for most applications, although it may very well (it's a very good encoding).
    I think it's great that we're experimenting with different solutions... I don't think there will ever be a single "one size fits all" best, and certainly a diverse selection of tools is good for the Propeller community (IMHO).
    If you want to take a peek at the PropGCC CMM code, which is still in development, you can look at the "compressedcode" branch of the source repository. We're using a byte code based interpreter, which likely has more overhead than the Catalina CMM kernel but which allows for potentially better compression. Here's the btea function of xxtea as produced by propeller-elf-gcc -Os -mcmm:
    GAS LISTING xxtea.s             page 1
       1                      .text
       2                      .global    _btea
       3                  _btea
       4 0000 0388             lpushm    #(8<<4)+8
       5 0002 2112             cmps    r1, #1 wz,wc
       6 0004 0B5061           xmov    r5,r0 mov r6,r1
       7 0007 4E0000           IF_BE    brw    #.L2
       8 000a 2611             sub    r6, #1
       9 000c 0AD6             mov    r13, r6
      10 000e A034             mov    r0, #52
      11 0010 2D29             shl    r13, #2
      12 0012 09               ldiv
      13 0013 1D50             add    r13, r5
      14 0015 E09660           xmov    r9,r6 add r0,#6
      15 0018 BC               mov    r12, #0
      16 0019 E98634           xmov    r8,r6 and r9,#3
      17 001c 17DD             rdlong    r7, r13
      18                  .L5
      19 001e 56B97937         mvi    r6,#-1640531527
      19      9E
      20 0023 1C60             add    r12, r6
      21 0025 E44C2A           xmov    r4,r12 shr r4,#2
      22 0028 2434             and    r4, #3
      23 002a 0A15             mov    r1, r5
      24 002c BB               mov    r11, #0
      25 002d 7F33             brs    #.L3
      26                  .L4
      27 002f E66B34           xmov    r6,r11 and r6,#3
      28 0032 D6E148           xmov    r14,r1 xor r6,r4
      29 0035 2E40             add    r14, #4
      30 0037 2629             shl    r6, #2
      31 0039 1620             add    r6, r2
      32 003b EAA749           xmov    r10,r7 shl r10,#4
      33 003e 2B10             add    r11, #1
      34 0040 1FED             rdlong    lr, r14
      35 0042 D33FC8           xmov    r3,lr xor r3,r12
      36 0045 166D             rdlong    r6, r6
      37 0047 1678             xor    r6, r7
      38 0049 1630             add    r6, r3
      39 004b E33F3A           xmov    r3,lr shr r3,#3
      40 004e 2F29             shl    lr, #2
      41 0050 275A             shr    r7, #5
      42 0052 13A8             xor    r3, r10
      43 0054 17F8             xor    r7, lr
      44 0056 1730             add    r7, r3
      45 0058 1768             xor    r7, r6
      46 005a 161D             rdlong    r6, r1
      47 005c 1760             add    r7, r6
      48 005e 171F             wrlong    r7, r1
      49 0060 0A1E             mov    r1, r14
      50                  .L3
      51 0062 1B83             cmp    r11, r8 wz,wc
      52 0064 7CC9             IF_B     brs    #.L4
      53 0066 115D             rdlong    r1, r5
      54 0068 0B6731           xmov    r6,r7 mov r3,r1
      55 006b 1498             xor    r4, r9
      56 006d 233A             shr    r3, #3
    GAS LISTING xxtea.s             page 2
      57 006f 2649             shl    r6, #4
      58 0071 2429             shl    r4, #2
      59 0073 1638             xor    r6, r3
      60 0075 0BF137           xmov    lr,r1 mov r3,r7
      61 0078 1420             add    r4, r2
      62 007a 235A             shr    r3, #5
      63 007c 2F29             shl    lr, #2
      64 007e 13F8             xor    r3, lr
      65 0080 11C8             xor    r1, r12
      66 0082 1630             add    r6, r3
      67 0084 FB010084         sub    r0, #1 wz
      68 0088 144D             rdlong    r4, r4
      69 008a 1748             xor    r7, r4
      70 008c 1710             add    r7, r1
      71 008e 1768             xor    r7, r6
      72 0090 16DD             rdlong    r6, r13
      73 0092 1760             add    r7, r6
      74 0094 17DF             wrlong    r7, r13
      75 0096 450000           IF_NE    brw    #.L5
      76 0099 4F0000           brw    #.L1
      77                  .L2
      78 009c 2716             neg    r7, #1
      79 009e 1172             cmps    r1, r7 wz,wc
      80 00a0 430000           IF_AE    brw    #.L1
      81 00a3 1416             neg    r4, r1
      82 00a5 A034             mov    r0, #52
      83 00a7 0B14A6           xmov    r1,r4 mov r10,r6
      84 00aa 09               ldiv
      85 00ab 51B97937         mvi    r1,#-1640531527
      85      9E
      86 00b0 2060             add    r0, #6
      87 00b2 3AFF8F           xor    r10,__MASK_FFFFFFFF
      88 00b5 0ADA             mov    r13, r10
      89 00b7 07               lmul
      90 00b8 E11411           xmov    r1,r4 sub r1,#1
      91 00bb 2129             shl    r1, #2
      92 00bd 2D29             shl    r13, #2
      93 00bf 1150             add    r1, r5
      94 00c1 1D50             add    r13, r5
      95 00c3 594786C8         mvi    r9,#1640531527
      95      61
      96 00c8 175D             rdlong    r7, r5
      97                  .L9
      98 00ca E3302A           xmov    r3,r0 shr r3,#2
      99 00cd 2334             and    r3, #3
     100 00cf 0BEAFD           xmov    r14,r10 mov lr,r13
     101 00d2 7F33             brs    #.L7
     102                  .L8
     103 00d4 E66E34           xmov    r6,r14 and r6,#3
     104 00d7 1638             xor    r6, r3
     105 00d9 E6BF29           xmov    r11,lr shl r6,#2
     106 00dc 2B41             sub    r11, #4
     107 00de 1620             add    r6, r2
     108 00e0 D44708           xmov    r4,r7 xor r4,r0
     109 00e3 E8873A           xmov    r8,r7 shr r8,#3
     110 00e6 2729             shl    r7, #2
     111 00e8 2E11             sub    r14, #1
    GAS LISTING xxtea.s             page 3
     112 00ea 1CBD             rdlong    r12, r11
     113 00ec 166D             rdlong    r6, r6
     114 00ee 16C8             xor    r6, r12
     115 00f0 1640             add    r6, r4
     116 00f2 E44C49           xmov    r4,r12 shl r4,#4
     117 00f5 2C5A             shr    r12, #5
     118 00f7 1C78             xor    r12, r7
     119 00f9 1488             xor    r4, r8
     120 00fb 14C0             add    r4, r12
     121 00fd 1648             xor    r6, r4
     122 00ff 17FD             rdlong    r7, lr
     123 0101 1761             sub    r7, r6
     124 0103 17FF             wrlong    r7, lr
     125 0105 0AFB             mov    lr, r11
     126                  .L7
     127 0107 2E02             cmps    r14, #0 wz,wc
     128 0109 75C9             IF_NE    brs    #.L8
     129 010b 1F1D             rdlong    lr, r1
     130 010d 0B674F           xmov    r6,r7 mov r4,lr
     131 0110 2449             shl    r4, #4
     132 0112 263A             shr    r6, #3
     133 0114 1648             xor    r6, r4
     134 0116 0BEF47           xmov    r14,lr mov r4,r7
     135 0119 2429             shl    r4, #2
     136 011b 2E5A             shr    r14, #5
     137 011d 2329             shl    r3, #2
     138 011f 14E8             xor    r4, r14
     139 0121 1320             add    r3, r2
     140 0123 1640             add    r6, r4
     141 0125 1708             xor    r7, r0
     142 0127 FA090080         add    r0, r9 wz
     143 012b 143D             rdlong    r4, r3
     144 012d 14F8             xor    r4, lr
     145 012f 1740             add    r7, r4
     146 0131 1678             xor    r6, r7
     147 0133 175D             rdlong    r7, r5
     148 0135 1761             sub    r7, r6
     149 0137 175F             wrlong    r7, r5
     150 0139 450000           IF_NE    brw    #.L9
     151                  .L1
     152 013c 048F             lpopm    #(8<<4)+15
     153 013e 0200             lret
    GAS LISTING xxtea.s             page 4
    DEFINED SYMBOLS
                   xxtea.s:3      .text:0000000000000000 _btea
                   xxtea.s:18     .text:000000000000001e .L5
                   xxtea.s:77     .text:000000000000009c .L2
                   xxtea.s:97     .text:00000000000000ca .L9
                   xxtea.s:151    .text:000000000000013c .L1
    NO UNDEFINED SYMBOLS
    Eric
    edited 2012-08-22 17:59
    ersmith wrote: »
    Eric
    I must admit I had not considered this case. Apart from this, I think a variadic function is the best answer (I think it may even be the only possible answer, given the way the function is supposed to handle character strings). The case you're trying to address seems to me to involve unspecified behavior anyway - do you know of any instances of people actually using these functions this way?
    edited 2012-08-22 18:52
    ersmith wrote: »
    Fair point. It's not a perfect encoding, but it's pretty darn good - and it's likely to be the best you can get for the types of programs the Propeller was intended to be used for (which is not, of course, the same as the types of programs that we actually use it for :smile:).
    ersmith wrote: »
    I agree. Unfortunately, I don't really have time to keep abreast of what's happening in GCC as well as keeping Catalina going, but thanks for the listing - very interesting. I tried byte encoding as my very first option, since I knew that would give you the best code sizes (I tried nearly everything - 8 bit, 16 bit, 24 bit and 32 bits, as well as many of the possible combinations of these). Yes, I could certainly get smaller code sizes with 8 bit encoding than the encoding I finally settled on (essentially, 16 bit) - but the resulting execution speeds were simply not compelling. Certainly not compelling enough to justify claiming that CMM could ever displace either LMM or Spin. Of course, you may be able to do a bit better than I managed - happy to wait and see.
    Ross.
    edited 2012-08-22 18:59
    RossH wrote: »
    It probably is an edge case, but I wanted to handle it correctly. Actually though I think there is another solution. Since the mapping between Spin and C does not have to be one to one, I can scan over the lookup statement and extract the index, creating code like:
       { int tmp__ = i++;
         int tmparray__[2] = { 0, 9};
         tmparray__[0] = i;
         r = lookupz(tmp__, 2, tmparray__);
    or something of that ilk. I'd like to stick with arrays if possible rather than variadic functions, because the performance will be better (especially for the common case of constant arrays). But providing a variadic lookup function in the library may be a good idea for people doing a port by hand.
    Thanks for your help with this!
    Eric
    edited 2012-08-22 20:00
    ersmith wrote: »
    No worries, since I didn't actually do anything :smile:. Do you intend to handle character strings the same way? - e.g. lookup(i : "abcd", 2, 3, 4). I'm not actually sure what the behavior should be in such cases - the manual seems to imply that if i = 1 it should return "a", and if i = 2 it should return "b", whereas I would have expected it to return the address of the string "abcd" if i = 1, and 2 if i = 2 - but I've not actually tried it.
    Ross.
    edited 2012-08-22 20:17
    If you want to implement lookupz exactly like the Spin interpreter does you have to evaluate each expression up to the indexed one. Consider the following example:
    x := lookupz(3 : i++, suba, y /= 5, subb, y *= 5)
    The expressions i++, suba and y /=5 will all be evaluated, but subb and y *= 5 will not be. This is an undocumented feature of lookupz, so it is probably not important to emulate this feature.
    edited 2012-08-22 20:25
    RossH wrote: »
    lookup(i : "abcd", 2, 3, 4) would produce the same result as lookup(i : "a", "b", "c", "d", 2, 3, 4). It would also produce the same result as lookup(i : "a".."d", 2..4).
    edited 2012-08-23 05:27
    Thanks, I've downloaded a copy of V0.96 to explore. Please consider the following a request, certainly not a complaint.
    I've tried to leave the Windows world behind and am using BST. Is there any way that this might be provided for other OSes?
    edited 2012-08-23 05:59
    Dave Hein wrote: »
    Oh wow, that's interesting. It also implies a completely different way of implementing lookup. I should probably look into it -- it's been my experience that if there's a weird undocumented feature of the Spin interpreter, then some program somewhere uses it :-).
    Eric
    edited 2012-08-23 06:04
    The source actually compiles under Linux (that's my "native" platform) and it's pretty generic code, so it should work on the Mac, too. If you're comfortable with the Linux or Mac command line, just pull down the source and type "make" in the spin2cpp directory. I should get around to posting a Linux binary one of these days, I just haven't had time.
    (Oh, and the Windows version works fine under Wine on Linux as well, except that the --elf option looks for propeller-elf-gcc.exe in the emulated Windows drive.)
    Eric
    edited 2012-08-23 06:54
    Thanks, I will try to compile the source. I have installed Wine in the past, but prefer not to use it as they seemed at that time to have made a real effort to withhold enough code to make you buy their 'better' version. Even under Linux, Wine and its directories are still available to viruses and hacking.
    But, I just see a couple of zip files for the Windows version, not the source code.
    I did manage to locate the source code and print a copy, but an unsure of how to go about downloading the actual file. The web site seems to insist that I 'clone' your site and I am not sure what that might lead to.
    So I'll use the .exe for now.
    edited 2012-08-23 07:56
    Linux is an open source operating system with a Unix-like heritage. It means that a source distribution should be able to compile on the computer assuming a minimum set of tools (make and gcc).
    Cloning means that you need a source control tool to get the source. Once you have the source, you can build the tool. That is all.
    What Linux do you use? I could probably make an application .zip or .tar for you.
    edited 2012-08-23 09:30
    I've uploaded a linux .zip file. Hopefully this will work for you.
    Cheers,
    Eric
    edited 2012-08-23 09:35
    For my own needs. it would be enough to include the .c source file in the zip rather than deal with whatever Google open-source community has in mind.
    But if you actually are not bothered by this, I use Ubuntu Linux. I am sure there will be others that may be more timid about using 'make' to generate a program. But that is a little absurd since we are taking about a tool for learning C and C++ so that we may do that compile process.
    Thanks for your concern. I will take a look at the Linux .zip
