Can you run DC power over AC lines?
Ok, this isn't anything as novel as trying to run both.
My Halloween project involves running dc motors, lights, and servos in multiple locations. I was originally
going to "go to town" with wall warts but have been having trouble finding 12v greater then 1amp.
Currently thinking of trying a computer power supply but this means running a lot of wires that
need to be water proofed (outdoor application).
I have a lot of heavy duty outdoor extension cords and was wondering if they would carry DC.
BTW - be sure to safeguard against some good Samaritan doing you a favor by plugging the cord into a 120V outlet. Perhaps you can put the power supply and cord ends in a box that can be locked.
No, remove the mains connectors and replace with mains incompatible connectors of some sort, you want to be _really sure_ noone will plug it into the wall.
Re an outdoor application, I had some extension leads outdoors for a year (yes, with plugs removed) and I was surprised to see green coming through the plastic through winter. That would be the copper oxidising and I guess the upshot is that extension leads are not really designed to be outside for long periods in the sun and moisture. A more robust (and thicker) 12V wire is the wire used for garden lights.
Linear type...
http://www.mouser.com/ProductDetail/Triad-Magnetics/WAU12-2000/?qs=%2fha2pyFadujrNpP0fcluIwxjmaNlkOTquFQ%252bUL409CSkBu6PKeH4WQ%3d%3d
Switching type...
http://www.digikey.com/product-search/en?lang=en&site=us&KeyWords=epsa120200u
http://www.monoprice.com/products/subdepartment.asp?c_id=110&cp_id=11009&cs_id=1100902
Includes a nice-ish box, and is cheap. Might be able to make your runs from one of these boxes, or use multiple of them in different locations to keep voltage drop to a minimum.
here is some irony ... that UL LOW VOLTAGE over rubberized zip cord is amazing at 15 kV!
so much darn rubbber it does well being fed off a 14.4 kV Pole pig/..
note I do use nylon tube over it for extra ommph in long term apps ..........
makes good speaker wire too.
and for DC BUT watch out . the polarity is not easy to see..
I'm not sure I should ask, but why are you connecting anything to a 14.4KV Pole pig?
Barbecue pork?
