Message for OBC
Dr_Acula
Message for OBC as too big to fit in the PM
This vb.net v 2008.
Declare this right at the beginning of the program
Imports System.IO.Ports
Imports Strings = Microsoft.VisualBasic ' so can use things like left( and right( for strings
and then this is the subroutine. Delay value of 50 seems about right.
This vb.net v 2008.
Sub XModemKyeSend(ByRef FName As String, ByVal Delay1 As Integer)
Dim Filenamepath As String
Dim a, j, i As Integer
Dim k As Integer
Dim LineOfText As String
Dim SerialString As String
Dim Counter As Integer
Dim ErrorString As String
Dim Packetnumber As Integer
Dim Checksum As Long
Dim OnesComplement As Byte
Dim ByteRead As Byte
Dim BinaryFileLength As Long
Dim BinaryFileCounter As Long
Dim Percent As Single
Dim ErrorCounter As Byte ' 0 to 10
Dim CPMFilename As String
Dim Timeout As Boolean
ProgressBar1.Maximum = 100
ProgressBar1.Minimum = 0
' timer restart =true for sending via menu. False for auto send
Filenamepath = FName
Packetnumber = 1 ' 1 for the first packet (not zero)
' Try
Dim Input As New FileStream(Filenamepath, FileMode.Open, FileAccess.Read)
Dim br As New BinaryReader(Input)
OpenSerialPort() ' open the serial port
Label3.Text = "Error Count"
Label2.Text = "0%"
BinaryFileLength = br.BaseStream.Length() - 1
'i = Len(Filepath) + 1 + 1 ' eg c:\n8vem and a \ = 9 and 1 more for start of name only
Call Get_CPM_Filename(Filenamepath, CPMFilename)
CPMFilename = Strings.UCase(CPMFilename)
LineOfText = "XMODEM R " + CPMFilename + vbCr
Call StringToPacket(LineOfText) '
Call ClearInputBuffer() ' clear the buffer into the PC
For i = 1 To Delay1 ' 50 for kyedos need to wait for kyedos to run the xmodem program
Sleep(100) ' wait for the xmodem text to come back so the next one is a 21
Label3.Text = Str$(i)
Next i
Do
SerialString = ""
If SerialPortFound = True Then
If SerialPortName.BytesToRead > 0 Then
SerialPortName.Read(InPacket, 0, 1) ' get one byte
SerialString = Chr(InPacket(0)) ' get a single character/string/byte
End If
End If
If InPacket(0) = 21 Then
ErrorString = "NAK"
Exit Do ' got a ^U
End If
If SerialString <> "" Then
'LineOfText = SerialString
'Call TextLines(LineOfText) ' print it out unless it is a chr21
End If
Counter = Counter + 10
Sleep(10) ' don't change this one - this is waiting for NAK
Label1.Text = "Waiting for NAK to start" + Strings.Str(Counter) + "ms" ' display in milliseconds
System.Windows.Forms.Application.DoEvents() ' update the label1 message
' add a counter and timeout if nothing
If Counter > 5000 Then
ErrorString = "Bypass wait for NAK - xmodem failed"
Exit Do
End If
If ErrorString <> "" Then Exit Do
Loop
Label1.Text = ErrorString
Do
' act on each byte in the buffer array here
XOut(0) = 1 'SOH ^A
XOut(1) = Packetnumber
OnesComplement = 255 - Packetnumber
XOut(2) = OnesComplement
Packetnumber = Packetnumber + 1
If Packetnumber > 255 Then Packetnumber = Packetnumber - 256
Checksum = 0
For i = 0 To 127 ' get 128 bytes from file
If BinaryFileCounter <= BinaryFileLength Then
ByteRead = br.ReadByte ' get a byte
Else
ByteRead = 26 ' pad with char 26 = hex 1A because hyperterm does this ? why but it works
End If
XOut(i + 3) = ByteRead
Checksum = Checksum + ByteRead
BinaryFileCounter = BinaryFileCounter + 1
Next
' create checksum
Do
If Checksum < 256 Then Exit Do ' work out checksum
Checksum = Checksum - 256
Loop
XOut(131) = Checksum
Call OutputXout()
Timeout = False
Do
k = 0
Do
j = SerialPortName.BytesToRead
End If
If j >= 1 Then
End If
Exit Do
End If
k += 1
If k > 5000 Then
Timeout = True ' 5 second delay for timeout, must be more than the Rx side timeout
Exit Do
End If
Sleep(1) ' 1ms delay
Loop
If InPacket(0) = 6 Then Exit Do ' remote got the packet so exit
' remote didn't get it so try sending again - does up to 10x
ErrorCounter = ErrorCounter + 1
Call ClearInputBuffer() ' clear the input buffer to the PC
Sleep(1000) ' let the remote get itself sorted before resending the packet
Call OutputXout() ' resend the packet
Label3.Text = "Nak: " + Strings.Str(ErrorCounter)
End If
If Timeout = True Then
Label3.Text = "Timeout waiting for Ack"
ErrorCounter = 20 'force an exit now
End If
If ErrorCounter >= 10 Then Exit Do ' more than 10 errors
Loop
Label1.Text = "10 or more errors - aborting"
Label2.Text = "0%"
OutPacket(0) = 24 ' send a ^X cancel
SerialPortName.Write(OutPacket, 0, 1) ' send 1 byte
OutPacket(0) = 3 ' send a ^C
End If
Exit Do
End If
If BinaryFileCounter > BinaryFileLength Then Exit Do ' finish up
Label1.Text = "Sent packet: " + Strings.Str(Packetnumber) + " = OK"
Percent = BinaryFileCounter / BinaryFileLength
Percent = Percent * 100
Percent = Int(Percent)
Label2.Text = Strings.Str(Percent) + "%"
ProgressBar1.Value = Percent
Loop
If ErrorCounter < 10 Then
OutPacket(0) = 4 ' finish byte
End If
Label2.Text = "100%"
Label1.Text = "Finished"
ProgressBar1.Value = 0 'done
Call StringToPacket(vbCrLf) ' back to kyedos
End If
Input.Close()
Sleep(200) ' wait for next file
System.Windows.Forms.Application.DoEvents() ' update the labels
'Catch ex As Exception
' Close()
' Label1.Text = Filenamepath + " not found"
' System.Windows.Forms.Application.DoEvents() ' update the labels
' Sleep(1000) ' so time to read message
'End Try
SerialPortName.Close() ' close the serial port
End Sub
Oldbitcollector (Jeff) wrote:Would you be kind enough to share what you are using on the PC end for Xmodem file transfer to Kyedos? Sounds like you've got a snappy little VB program created to make things easy. (Still fighting with Hyperterm here.)
Jeff
I'm having trouble getting this to compile with the tools I have.
Jeff
It may not compile with 2010 - I'm using 2008. But it should be possible to port things over.
.net files are created in a directory with multiple sub directories but it should unzip with all that directory structure intact and hopefully the .sln file will open it.
-Jeff
