How does a resistor to ground from transmit pin effect power output?
purplemonkey
Just trying to get my head round this... Cant figure out how a resistor instead of antenna is more powerful, Is it that the lower the resistor value the higher the power output? So for instance if I had 25 ohm resistor on transmit pin what would be the watts it would output and what sort of range would it be?
Yes, 25 ohm resister causes more current to flow.
However, the resister is probably not the thing doing the transmitting.
A resister is physically to small to do it. You need an antenna.
In your case the antenna is the ancillary wiring to the regulator and the power buses.
The resistor causes switched current to flow in these things which now act as antennas.
Duane J
The ARRL Antenna Book and the ARRL's Amateur Radio Handbook are good references for this sort of stuff.
Oh ok i understand thanks, what is the impedence on the prop pins? And what length of wire would match the impedence?
As when I tested it with a 32cm piece of wire I only was getting about 6 ft before signal dropped off dramatically. What is the unadulterated output of the transmit pin just with this type of antenna?
On FM choosing a frequency on a relatively quiet channel, (not easy in a big city like the Dallas Fort Worth area I live in), I received a strong signal in a quarter mile radious on my car's OEM FM radio on a random wire w/o any other external components. A very strong signal was received on my Sony stereo receiver On my bench with nothing at all connected to the output pin. What sort of receiver are you using? Something with a PLL design (i.e. has a digital readout) should work a lot better as it will track the TXer's center frequency output drift.
Antenna design, especially TX can get very complicated. I think it was Chip who suggested an LRC tank circuit that effectvelty increases the output of a TV broadcast power output by at least an order of magnitude.
Also, a halfway decent receiver will receive the strongest signal on a given channel "ignoring" lower strength signal on that channel.
