How to control a brushless motor using the prop
I require to use a brushless motor(in an oxygen rich envirnment - no sparking) - The motor I have is used in model planes- E-Flite power 32.
I plan to gear it down to slower RPM for my use.They are normally used Elecronic Speed Controlle(ESC)- which are expensive and I do not
all other functions/contrls associated with flying.Minimum to turn on/off - the motor,if I van control the RPM's is excellent.
The motor has 3 connections - Black/Red - power connections and a blue(? speed contol).
Can this be simply controoled with a potentiometer manual/electronic.or is there motor driver available to use with the prop.
Thank you.
Siri
P.S - The motor specs are attached.
Thank you.
Siri
If the ESC is too expensive, find a cheaper ESC. HobbyKing.com has a lot of cheap ESCs, and it's probably best you use one of those, but be sure to downgrade it since they're designed to have propeller airflow past them for the power ratings they state.
How much power/torque do you actually need in your environment? That's a really powerful motor (about one horsepower).
You can have a microcontroller read the speed by using: http://www.espritmodel.com/brushless-rpm-sensor-v2.aspx
@ Circuitsoft
You're making an ESC? This guy was making one, but he disappear. Any chance you'll make a version with four outputs for quadrotor usage?
I am at the moment is using a 1/4HP AC motor - it works well with it.I am not using oxygen at the moment - just air.I see the sparking at the brushes.
S that is why I am trying to use a BLDC motor.
Thanks for the Help.
Siri
I agree with the suggestion to use an inexpensive ESC from HobbyKing.
I am using the motore to drive a gas pump.It needs some torque as the pump starts and stops about every second.Notmuch pressure is involved
only about 10cm of water.
Thanks for your help.
Siri
A stepper motor might work well too, inexpensive and easy to control.
http://www.amazon.com/Rule-24-Marine-360-GPH-12-Volt/dp/B000O8D8QG/ref=sr_1_5?s=sporting-goods&ie=UTF8&qid=1345067714&sr=1-5&keywords=bilge+pump
I am very glad I pu this on the forum,I have learned a lot about BLDC/RC motors.I will continue to look for a suitable BLDC motor.
@W9GFO - I am pumping oxygen/oxygen+air and the pump has to be small and light weight as it has to be very potable.
I will keep all the advise in mind when searching for the BLDC motor..
Thank you very much for all the advise.
Siri
