Parallax RFID 28440 Rev. A
Hi guys,
Can you tell if i can use the Parallax RFID Read Write module with USB2SER connected on computer?
I have purchaged both products but i am not able to communicate with the RFID from the terminal software.
:nerd:
best regards,
Windux
:nerd:
best regards,
Windux
Yes, i am trying to connect the RFID with USB2SER directly to a USB port from my computer using Putty as Terminal.
When i press any key from the keyboard, a blue light blinks on the USB2SER device but no input or output from RFID module.
best regards,
Windux
I have tried from many ways connecting both devices without success.
My connections are like this:
COMPUTER USB PORT -> USB2SER -> RFID
No luck with this hardware
best regards,
Windux
The two devices are connected directly: RFID=>USB2SER=>USB COMPUTER PORT
THe Baud Rate are correct 9600-8n1
best regards,
Windux
Can you provide a picture?
The connections is:
RFID <-> USB2SER
VCC<->VSS
SIN<->RX
SOUT<->TX
GND<->RES
I have already inverted the connection and the result is that RFID Led is always ON.
best regards,
Windux
There are other USB to serial adapters that provide regulated +5V from the USB bus, but the USB2SER adapter does not do this. Many such USB adapters will only provide up to 100mA which is not enough for the RFID module. You'd need an adapter designed to provide at least 200mA.
Can you suggest me one adapter to connect my RFID?
best regards,
Windux
